Partial Fraction Decomposition
In summary, Partial Fraction Decomposition is a mathematical technique used to break down rational functions into simpler fractions, making them easier to integrate or analyze. This method involves expressing a given rational function as a sum of simpler fractions whose denominators are factors of the original function's denominator. The process typically requires determining the appropriate coefficients for these simpler fractions through algebraic manipulation, often involving polynomial long division if the degree of the numerator is greater than or equal to that of the denominator. This technique is widely used in calculus, especially in solving integrals and differential equations.
hackedagainanda
52
Find the partial fraction decomposition of the rational=##\frac {1} {x^2 -c^2}## with ##c \neq {0}##
N/A
So the first thing I do is split the ##x^2 -c^2## into the difference of squares so ##x +c## and ##x - c##
I then do ##\frac {A} {x + c}## ##+## ##\frac {B} {x-c}##, and then let ##x=c## to zero out the expression. And that is where I am getting lost I don't see where to go from here, I don't understand where the ##2c## in the denominator is coming from.
The solution in the book is ##\frac {1} {2c(x-c)}## ##-\frac {1} {2c(x+c)}##
You set the partial fraction equal to the original fraction and then solve for A and B.
Likes e_jane
I think I got it Ax + Bx = 0 and adding -Ac + Bc =1 A-A =0 add the B's and get 2B = 1 so B= 1/2 and A = -1/2, there is no x term in the numerator so we can move along to the variable c, -Ac = -1/2c and B = 1/2c so that lines up with the books answer.
Thanks for the suggestion and help, did I make any mistakes?
I cannot tell exactly what you are doing. For future questions, you will need to be clearer.
Here’s how I do it.
The first equation can be written as (A+B)x=0. Since this has to hold for all values of x, this implies A=-B.
The second equation can now be rewritten
(B-A)c=1
2Bc=1
B=1/(2c) (notice that you are dividing by c, so that it cannot equal 0
  • Love
Likes e_jane, FactChecker and hackedagainanda
(B-A)c=1
2Bc=1.
B=1/2c (notice that you are dividing by c, so that it cannot equal 0.
1/2c would normally be read as one half times c. To convey the idea that c is in the denominator, write 1/(2c) or ##\frac 1 {2c}##.
Likes e_jane
FAQ: Partial Fraction Decomposition
What is Partial Fraction Decomposition?
Partial Fraction Decomposition is a method used in algebra to break down a complex rational function into a sum of simpler fractions, which are easier to integrate or differentiate. This technique is particularly useful in calculus and differential equations.
When is Partial Fraction Decomposition applicable?
Partial Fraction Decomposition is applicable when dealing with rational functions, which are ratios of two polynomials. The degree of the numerator must be less than the degree of the denominator. If not, polynomial long division must be performed first.
How do you perform Partial Fraction Decomposition?
To perform Partial Fraction Decomposition, follow these steps:1. Factor the denominator into its irreducible factors.2. Write the decomposed form with unknown coefficients for each factor.3. Multiply through by the common denominator to clear the fractions.4. Solve the resulting system of equations to find the unknown coefficients.
What are the different types of partial fractions?
The different types of partial fractions depend on the nature of the factors in the denominator:1. Distinct linear factors: Each factor contributes a term of the form A/(linear factor).2. Repeated linear factors: Each repeated factor contributes terms of the form A/(linear factor) + B/(linear factor)^2, and so on.3. Irreducible quadratic factors: Each factor contributes a term of the form (Ax + B)/(quadratic factor).
Why is Partial Fraction Decomposition important?
Partial Fraction Decomposition is important because it simplifies complex rational functions, making them easier to integrate or differentiate. This technique is widely used in calculus, control systems, signal processing, and other fields of engineering and science.
