MHB Partial fractions (5x^2+1)/[(3x+2)(x^2+3)]
The discussion focuses on solving the partial fraction decomposition of the expression (5x^2+1)/[(3x+2)(x^2+3)]. Participants identify a typo in the setup of the equation, clarifying that the correct form should include (Bx+C)(3x+2) in the numerator. They suggest substituting x=-2/3 to find the value of A, leading to the calculation of coefficients through comparison. The final values determined for the constants are A=-1, B=2, and C=2. This process highlights the importance of accurate notation and methodical coefficient comparison in partial fraction decomposition.
mathlearn
Trouble here in the below partial fraction (Bug)
$\frac{5x^2+1}{(3x+2)(x^2+3)}$
One factor in the denominator is a quadratic expression
Split this into two parts A&B
$\frac{5x^2+1}{(3x+2)(x^2+3)}=\frac{A}{(3x+2)}+\frac{Bx+c}{(x^2+3)}$
$\frac{5x^2+1}{(3x+2)(x^2+3)}=\frac{A(x^2+3)}{(3x+2)}+\frac{Bx+c (3x+2)}{(x^2+3)}$
${5x^2+1}={A(x^2+3)}+{Bx+c (3x+2)}{}$
and cannot take it from here
Mathematics news on Phys.org
Hi mathlearn,
I believe you have a typo in your last line, it should be:
${5x^2+1}={A(x^2+3)}+(Bx+C) (3x+2)$
One way to move forward is to substitute $x=-2/3$, effectively zeroing the last term (which allows you to solve for $A$). Once we have $A$, unfortunately, we'll have to expand out all the terms and compare the coefficients of both sides of the equation.
Let's use a better method;
(5x^2+1)/(3x+2)(x^2+3) = A/(3x+2) + (Bx+C)/(x^2+3)
To find A,multiplying both sides of the equality by (3x+2) ;
(5x^2+1)/(x^2+3) =A + (3x+2)(Bx+C)/(x^2+3) (1)
Now,setting x=-2/3 or 3x+2=0,makes the expression on the right containing (3x+2) vanish,so(5(-2/3)^2+1)/((-2/3)^2+3) =A + 0 .Then,
A=29/31To find C,set x=0 in (1),so we get rid of b.Then,
1/3=29/31 +2C/3
So,c can be easily calculated.
To find b,plugging any number but -2/3 & 0 into x,say 1,
6/5=29/31 + 5(B+C)/4
We have found C,then B can be easily calculated.
Actually there are a number of mistakes- though probably mostly typos.
Okay.
No, the fractions on the right must both have "$(x^2+ 3)(3x+ 2)$" as denominator and the final fraction should have numerator (Bx+c)(3x+ 2) not "Bx+ c(3x+ 2)".
Again that should be (Bx+ c)(3x+ 2).
$5x^2+ 1= Ax^2+ 3A+ 3Bx^2+ 3cx+ 2Bx+ 2c$
$5x^2+ 0x+ 1= (A+ 3B)x^2+ (3c+ 2B)x+ (3A+ 2c)$
Since this is t0 be true for all x, "corresponding coefficients must be equal:
5= A+ 3B, 0= 3c+ 2B, and 1= 3A+ 2c
Subtract 3 times the second equation from twice the first:
10- 0= 2A+ 6B- 6c- 6B= 2A- 6c
Subtract 3(1= 3A+ 2c), 3= 9A- 6c from that:
7= -7A so A= -1. Then -3+ 2c= 1 so 2c= 4 and c= 2.
5= -1+ 3B so 3B= 6, B= 2.
A= -1, B= 2, and c= 2.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
