Partial fractions on exponentials
In summary, the partial fractions won't work in this instance because you can't make a useful substitution.
CuriousJ
Is it possible to use partial fractions on exponential factors? An expression like this for example...
3^x
______________________
(2^x + 3^x)(5^x + 6^x)
Would it break down into something like this?
A^x/(2^x + 3^x) + B^x/(5^x + 6^x)
What are the rules for repeated factors and non-repeated, etc.? I am trying to figure out how the rules for partial fractions would apply to this type of problem. How would I solve for A and B?
Hi CuriousJ! :smile:
(try using the X2 tag just above the Reply box :wink:)
3^x
No, it's not possible …
you'd have an equation (I'll use f(x) and g(x) instead of your Ax and Bx) like f(x)(5x + 6x) + g(x)(2x + 3x) = 3x, which isn't going to work. :wink:
Could you use it if you made a substitution? If you had to integrate 1/ex2+2ex+1 you'd want to substitute u=ex then use partial fractions.
As long as you meant [itex]1/(e^{2x} + 2e^x + 1)[/itex] (that is, [itex]e^{2x}[/itex] as opposed to [itex]e^{x^2}[/itex], which is quite different), yes, I see no problems with using a "substitution" like that to partial fraction decompose it, for the particular case you've given.
The problem with the example in the OP is that you can't make a useful substitution like that in order to decompose the expression. You could write each term as u^{ln(b)}, where u = e^x and b is whatever the base of the exponential was, but the ln(b)'s won't be integers and so the decomposition would fail.
In order for the decomposition to work you'd need either all of the bases to be the same or integers powers of the lowest base.
Right, e^2x. Thanks for catching that.
The decomposition seems to work when the denominator is a conjugate pair and the numerator can be reduced to one of those bases...
Example:
2^x/((2^x + 5^x)(2^x - 5^x)) = 1/[2(5^x + 2^x)] - 1/[2(5^x - 2^x)]
Thanks tiny-tim and Mute, for answering my question. :smile:
FAQ: Partial fractions on exponentials
What are partial fractions on exponentials?
Partial fractions on exponentials is a mathematical technique used to simplify complex algebraic expressions involving exponential functions. It involves breaking down a single fraction with multiple terms into smaller fractions with simpler denominators.
Why are partial fractions on exponentials useful?
Partial fractions on exponentials are useful because they allow us to solve integrals and differential equations involving exponential functions. They also help us to simplify complex algebraic expressions and make them easier to work with.
How do you decompose an exponential function into partial fractions?
The process of decomposing an exponential function into partial fractions involves identifying the distinct factors in the denominator and writing them as separate fractions with undetermined coefficients. These coefficients can then be solved for using algebraic techniques.
Can partial fractions on exponentials be used for improper fractions?
Yes, partial fractions on exponentials can be used for improper fractions. The process is the same as for proper fractions, but the result will include a polynomial term in the numerator as well.
What are some examples of applications of partial fractions on exponentials?
Partial fractions on exponentials are commonly used in calculus to solve integrals involving exponential functions, in differential equations to find solutions involving exponential functions, and in engineering and physics to model real-world phenomena.
