Happiness
- 690
- 31
Integration as antiderivative
Question: Why isn't a distinction made between anti-total-derivatives and anti-partial-derivatives in common usage of integration?
Consider the functions ##G_1(x, t)## and ##F(x, t)## such that ##F(x, t)=\frac{d}{dx}G_1(x, t)=\frac{\partial G}{\partial x}+\frac{dt}{dx}\frac{\partial G}{\partial t}=\frac{\partial G}{\partial x}+\frac{1}{v}\frac{\partial G}{\partial t}##, where ##v=\frac{dx}{dt}## is the velocity.
Then we define ##G_1(x, t)## as the anti-total-derivative (also known as the total-integration) of ##F(x, t)## with respect to ##x##. ##F(x, t)=\frac{d}{dx}G_1(x, t)\iff G_1(x, t)=\int_a^xF(x', t(x'))d_{full}x'+c##, where ##a## and ##c## are constants.
Next, consider the functions ##G_2(x, t)## and ##F(x, t)## such that ##F(x, t)=\frac{\partial}{\partial x}G_2(x, t)##.
Then we define ##G_2(x, t)## as the anti-partial-derivative (also known as the partial-integration) of ##F(x, t)## with respect to ##x##. ##F(x, t)=\frac{\partial}{\partial x}G_2(x, t)\iff G_2(x, t)=\int_{a(y)}^xF(x', t(x'))d_{partial}x'+c(y)##.
Example: Partial integration
Question: Is equation (2) below correct?
Consider a force ##F## that varies with displacement ##x## and time ##t##. In general, the acceleration ##a## and velocity ##v## of a particle subjected to such a force also vary with ##x## and ##t##.
##a=\frac{\partial v}{\partial x}\frac{dx}{dt}+\frac{\partial v}{\partial t}=v\frac{\partial v}{\partial x}+\frac{\partial v}{\partial t}##
Since ##F=ma=mv\frac{\partial v}{\partial x}+m\frac{\partial v}{\partial t}##,
##mv\frac{\partial v}{\partial x}=F-m\frac{\partial v}{\partial t}.\,\,\,\,\,## -------- (1)
Integrating (partial-integration) both sides wrt ##x##,
##\int mv\frac{\partial v}{\partial x} d_{partial}x=\int(F(x, t)-m\frac{\partial v}{\partial t})d_{partial}x##
##\frac{1}{2}mv^2=g(x, t)+h(t)\,\,\,\,\,## -------- (2) Is this correct?
where ##\frac{\partial}{\partial x}g(x, t)=F(x, t)-m\frac{\partial v(x, t)}{\partial t}##.
Example: Total differential
Question: I obtain below ##\frac{\partial v}{\partial t}=0##, which is inconsistent with ##F(x, t)##. What's wrong?
Multiplying ##dx## to both sides of (1),
##mv\frac{\partial v}{\partial x}dx=(F-m\frac{\partial v}{\partial t})dx##.
Adding ##mv\frac{\partial v}{\partial t}dt## to both sides,
##mv(\frac{\partial v}{\partial x}dx+\frac{\partial v}{\partial t}dt)=(F-m\frac{\partial v}{\partial t})dx+mv\frac{\partial v}{\partial t}dt.\,\,\,\,\,## -------- (3)
Since ##dv=\frac{\partial v}{\partial x}dx+\frac{\partial v}{\partial t}dt## and ##vdt=dx##,
##mvdv=(F-m\frac{\partial v}{\partial t})dx+m\frac{\partial v}{\partial t}dx=Fdx##.
Integrating both sides,
##\frac{1}{2}mv^2=\int F(x, t)dx##.
I believe the integration on the RHS should be a partial-integration. (But why?) Then
##\frac{1}{2}mv^2=G(x, t)+H(t)## (This is consistent with equation (2).)
where ##\frac{\partial}{\partial x}G(x, t)=F(x, t)##.
But simplifying the RHS of (3), we have
##mv\frac{\partial v}{\partial x}dx+mv\frac{\partial v}{\partial t}dt=Fdx+0dt##
By comparing terms with ##dt##, we deduce
##\frac{\partial v}{\partial t}=0##.
But this is inconsistent with a time-dependent force ##F(x, t)##. What's wrong?
