MHB Partial Order Relation on Positive Rational Numbers and Numbers Greater Than 1/2
  • Thread starter Thread starter sbrajagopal2690
    Functions Relations
The discussion focuses on the relation r defined on the set of positive rational numbers Q+, where (x,y) ∈ r if x/y is an integer. Participants are tasked with demonstrating that r is a partial order by proving reflexivity, antisymmetry, and transitivity. Additionally, they need to identify all positive rational numbers greater than 1/2 within this relation. A suggestion is made to analyze the fraction p/q, where p and q are coprime, to derive insights about their relationship when greater than 1/2. The conversation emphasizes the mathematical properties of the relation and the implications for identifying specific rational numbers.
sbrajagopal2690
need help on this ..any suggestions are highly appreciatedConsider the set of positive rational numbers Q+ . Consider the relation r defined by
(x,y) ∈ r<=> x/y ∈ Z. Show that r is a partial order and determine all numbers greater than 1/2.
Re: relations and functions
sbrajagopal2690 said:
Consider the set of positive rational numbers Q+ . Consider the relation r defined by (x,y) ∈ r<=> x/y ∈ Z. Show that r is a partial order and determine all numbers greater than 1/2.
You must show that this relation is
a R a (reflexivity) for all;
if a R b and b R a then a = b (antisymmetry);
if a R b and R ≤ c then a R c (transitivity).
I have no idea what "determine all numbers greater than 1/2" could mean?
... determine all numbers greater than 1/2.
Suppose that $p/q$ is greater than $1/2$ in this ordering (where $p/q$ is a fraction in its reduced form, so that $p$ and $q$ have no common factors other than $1$). Then $\left.\frac12\middle/\frac pq\right.$ is an integer. Simplify that compound fraction and see what that tells you about $p$ and $q$.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
