Partial Order Relation where the Set is not Necessarily Finite
In summary, we discussed partial order relations on a set A and determined the truth or falsity of several statements related to this topic. We found that statements 1 and 2 are false, as there exist counterexamples to both. Statement 3 is true, as an infinite set cannot have a maximal element. Statement 4 is true, as the definition of a smallest element aligns with the given scenario. Statement 5 is false, as there exist counterexamples to this statement as well. We also discussed the relationship between infinite sets and maximal elements, concluding that an infinite set may or may not have a maximal element.
Yankel
395
Hello all,
I have another question about partial order relations, again, a few statements which are either true or false.
R is a partial order relation on a set A which is not necessarily finite.
1) With this order, A has at least one maximal and one minimal elements.
2) If with this order, A has a smallest and largest elements, then every two element of A are comparable.
3) If with this order, A has no maximal elements, then A is infinite.
4) if with this order, A has a single minimal element, then it is a smallest element.
5) If every two elements are comparable, then there is a smallest and largest elements.I think that 3 and 4 are true and the others are false, but I am not sure. Statement 3 is very intuitive. So is 4. I am quite sure over 5 as well (being false). Statements 1 and 2 are confusing a bit.
Can you think of an example which can show this ?
Thank you !
Yankel said:
Hello all,
False. The set of integers with the usual order is a counterexample.
False. The set of all subsets of A, ordered by inclusion, is a counterexample. A itself is "largest", the empty set is "smallest".
This is true.
That looks like the usual definition of "smallest element"?
False. The set of integers, with the usual order, is a counterexample.
Thank you !
No, the definition says the smallest element is less than or equal to every element. I think 4) is false.
Thank you both !
Can you explain number 2 ?
I don't get it. First of all, are you saying that if for example A=N (naturals), then P(N) has a largest element, which is N?
If so, how come not every two elements of P(N) are comparable?
Yes, every subset of $A$ (i.e., element of $P(A)$) is a subset of $A$ (i.e., less than or equal to $A$).
I think you missed the definition of the order here ("by inclusion"). Otherwise I am puzzled by the difficulty you are having.
I might have missed the definition. If the relation is the subset relation, two elements are comparable if one is a subset of the other? For example, if A={1,2}, then P(A)={empty, {1}, {2},{1,2}}, and I say that {1} and {2} are NOT comparable?
Statement 3 say that if there is no maximal element, the set is infinite. And you guys are saying it's true. So it DOESN'T work on the other way, "if a set is infinite it doesn't have a maximal element", because of the example of the naturals with the subset relation. Did I understand correctly?
This is interesting...
Yes.
Yes, because for every element there is a greater one, and this chain cannot loop due to transitivity and irreflexivity of strict order.
I wouldn't say "So" because what follows is not implied by statement 3. But you are correct: an infinite set may have a maximal element. The simplest example is negative integers. An infinite set may be linearly ordered and have both least and greatest elements, e.g., $\{0\}\cup\{1/n\mid n\in\mathbb{Z}^+\}$.
FAQ: Partial Order Relation where the Set is not Necessarily Finite
What is a partial order relation?
A partial order relation is a mathematical concept where a set of elements is partially ordered based on a relation between them. This relation follows the properties of reflexivity, antisymmetry, and transitivity.
How is a partial order relation different from a total order relation?
A total order relation is a complete ordering of a set of elements, where every element is comparable to every other element. In contrast, a partial order relation only requires some elements to be comparable and does not require all elements to be ordered.
Can a partial order relation have cycles?
No, a partial order relation cannot have cycles. This would violate the transitivity property, where if A is related to B and B is related to C, then A must also be related to C. Cycles would create contradictory relations and therefore are not allowed in a partial order relation.
How is a partial order relation represented?
A partial order relation can be represented as a directed graph, where the elements are the vertices and the relation between them is represented by directed edges. The absence of an edge indicates that there is no relation between those elements.
Can a partial order relation be infinite?
Yes, a partial order relation can be infinite. It is not necessary for the set of elements to be finite for a partial order relation to exist. As long as the properties of reflexivity, antisymmetry, and transitivity are satisfied, a partial order relation can exist on an infinite set of elements.
