Partial Order/Upper Bound Proof from How to Prove It
In summary, the author is trying to prove that if x is an upper bound for B, then bRx. However, he is not able to do this because there is no defined "<" in this partial order.
zooxanthellae
157
Partial Order/Upper Bound Proof from "How to Prove It"
Suppose R is a partial order on A and B is a subset of A. Let U be the set of all upper bounds for B. Prove that U is closed upward; that is, prove that if x E U and xRy then y E U.
N/A
This is Velleman's:
Suppose that x E U and xRy. To prove that y E U, we must show that y is an upper bound for B, so suppose that b E B. Since x E U, x is an upper bound for B, so bRx...
The proof goes on, but I am stuck at the bolded part. How do we know that the relation R is a relation such that, if x > b, then bRx? What if the relation R is defined as: {(x,y) E A x A | x >= y}? Isn't my definition of R reflexive, transitive, and antisymmetric, and therefore partially ordered, as the given states? And wouldn't my definition then mean that, if x > b, it is not true that bRx? Where am I going wrong?
Thanks in advance.
What you wrote is a partial order, but obviously the author intended this partial order is xRy if x<y
But, taking my literalist, unsubtle (more charitably: rigorous) approach, is my objection valid?
No, it is not. There is no "< " defined. The author is taking "aRb" as the order relation and defining "upper bound" in terms of that relation. Saying that "x is an upper bound on set B then, by definition of "upper bound", bRx for all b in B.
You cannot object to a statement in terms of symbols or relations that have not been defined for that particular statement.
But how is he able to say that bRx immediately follows if x >= all b in B?
I don't think I understand this part of your answer:
He didn't. He said that bRx follows from x being an upper bound for B.
You have thoroughly confused yourself by introducing a second partial order and mixing the two of them up.
If you're studying two orders at once, you really should qualify all order-related terms so you know which order it's related to.
Wait, how is what I said different from what you said? Isn't an upper bound defined as an element that is greater than or equal to every element in some subset?
In other words, how is "x >= all b in B" different from "x being an upper bound for B"?
Yes. But don't confuse the order R with the order [itex]\leq[/itex]. "x is greater than or equal to y" literally means "yRx" in this order!
>_< How can I not confuse R with <= when you've just said that x >= y implies yRx; in other words, x <= y implies xRy!
I never said I am using the word "greater" relative to the ordering [itex]\leq[/itex]!
I think I'm going to re-read the chapter this question comes from. It's pretty clear I don't understand it very well, since I still can't understand the last post!
Topic closed, for the time being, I suppose?
Related to Partial Order/Upper Bound Proof from How to Prove It
1. What is a partial order?
A partial order is a mathematical relationship between elements in a set that is reflexive, antisymmetric, and transitive. This means that for any element a in the set, a is related to itself, and if a is related to b, then b cannot be related to a. Additionally, if a is related to b and b is related to c, then a is also related to c.
2. What is an upper bound?
An upper bound is an element in a set that is greater than or equal to all other elements in the set. In other words, it is the maximum value in the set.
3. How do you prove a partial order?
To prove a partial order, you must show that the relationship between elements in the set is reflexive, antisymmetric, and transitive. This can be done by providing specific examples or by using logical reasoning and mathematical notation.
4. What is a proof of an upper bound?
A proof of an upper bound involves showing that the upper bound is indeed greater than or equal to all other elements in the set. This can be done by using mathematical notation and logical reasoning, similar to proving a partial order.
5. Can a set have more than one upper bound?
Yes, a set can have multiple upper bounds. In fact, any element in the set that is greater than or equal to all other elements can be considered an upper bound. This means that there can be an infinite number of upper bounds in a set.
