MHB Partially Decoupled System with 3 variables
  • Thread starter Thread starter Omzyma
    System Variables
Omzyma
Hello!
I have the following initial value problem:
\[ x' = x + 2y + 3z \]
\[ y' = 4y + 5z \]
\[ z' = 6z \]
All I'm looking to do is find the general solution to this system, and as long as I'm doing this correctly I have these answers:
\[ y(t) = K_2e^{4t} + \tfrac{5K_1}{2}e^{6t} \]
\[ z(t)=K_1e^{6t} \]
But I'm having trouble getting x(t) to finish this up. Any help on what my next steps should be?
Omzyma said:
Hello!
\[ y' = 4y + 5z \]
\[ z' = 6z \]
I agree with your solutions to z(t) and y(t). What's the difficulty? You will have
[math]x' = x + 2 \left ( K_2 e^{4t} \right ) + 3 \left ( \dfrac{5}{2} K_1 e^{6t} \right )[/math]
You've shown you can solve the homogeneous equation. So pick your particular solution: [math]x_p = A \left ( e^{4t} \right )+ B \left ( e^{6t} \right )[/math]
-Dan
-Dan
Thanks for your reply!
Picking [math]x_p = A \left ( e^{4t} \right )+ B \left ( e^{6t} \right )[/math] as my particular solution I ended up with [math]3A \left ( e^{4t} \right )+ 5B \left ( e^{6t} \right ) = 2K_2 \left ( e^{4t} \right ) + 3K_1 \left ( e^{6t} \right )[/math]
At this point do I solve for both A and B simultaneously, making either A or B as function of the other? Or should I just make like terms equal to each other and solve for A and B individually?
If you have [math]3A \left ( e^{4t} \right )+ 5B \left ( e^{6t} \right ) = 2K_2 \left ( e^{4t} \right ) + 3K_1 \left ( e^{6t} \right )[/math] true for all t then [math]3A = 2 K_2[/math] and [math]5B = 3 K_1[/math].
-Dan
-Dan
So that would mean [math] A=\tfrac{2}{3} [/math] and [math] B = \tfrac{3}{5}! [/math]
Thanks for your help. Just needed a little nudge I guess.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
