Particle collides totally inelastically with a vertical free rod
In a totally inelastic collision, a particle of mass M collides with a vertical rod of the same mass, resulting in a combined system that rotates about its center of mass. The conservation of momentum and angular momentum principles are crucial for solving the problem. The center-of-mass velocity can be determined using these conservation laws, while the moment of inertia is calculated based on the combined masses and geometry. The angular speed of the system post-collision is derived from the moment of inertia and the linear velocity. Understanding the rotation point as the center of mass is essential for accurate calculations.
rbwang1225
A particle of mass M moving on a frictionless surface with velocity ##V_0## collides totally inelastically with an uniform vertical rod of mass M and length L. After immediately the collision, what is the center-of-mass velocity, the moment of inertia about the center-of-mass, and the angular speed of the system.
conservation of momentum and conservation of angular momentum
moment of inertia
I am wondering what point does the particle+rod system will rotate about?
First form the two equations. Conservation of linear and Conservation of angular momentum. As there is no external force and Torque.
The problem statement mentions "the moment of inertia about the center-of-mass", so that is a pretty good clue.
  • · Replies 71 ·
16K
  • · Replies 18 ·
