Particle experiencing only an angular force, determine the r dot
  • Thread starter flinnbella
  • Tags
    Particle
In summary, the analysis of a particle under the influence of an angular force involves determining the rate of change of the radial distance, denoted as r dot (ṙ). The angular force affects the particle's motion by altering its angular momentum, and through the application of rotational dynamics, one can derive the relationship between angular force and ṙ, considering factors such as mass, angular velocity, and the geometry of the system.
flinnbella
Consider a particle that feels an angular force only, of the form Fθ = m r' θ'.
Determine the dependence of r' on r.
Relevant equations are:
particle acceleration in polar coordinates
Fr = 0
F(theta) = mr'θ'.
Hey, I've been working on this for a couple hours, and still no luck.
Since the force in the radial direction is zero, I set
r'' = rθ'^2.
Then since Fθ = m r' θ' and, since it's in polar coordinates, Fθ = m(2r'θ' + rθ'').
Setting these two equal, I get: -r'θ' = rθ''
At this point, I'm stumped. I try to substitute the angular velocity/ acceleration for something in terms of r, try to integrate, but inevitably I reach a point where I can't integrate anymore.
flinnbella said:
Homework Statement: Consider a particle that feels an angular force only, of the form Fθ = m r' θ'.
Relevant Equations: Relevant equations are:
Fr = 0
F(theta) = mr'θ'.
r'' = rθ'^2.
You can rewrite that as$$r\ddot \theta + \dot r \dot \theta = 0$$Do you recognise an exact time derivative there?
Likes erobz
PS you also have another equation of motion from the ##\hat r## component.
PPS is the question to get the dependence of ##\ddot r## on ##r##? I.e. a differential equation for ##r##.
As far as I can tell it's either what you suggest ( which is very clean ), or you get ##\dot r ## as a function of ##r, \ddot r , \dddot r##.
What can be considered "an angular force" in this type of problems?
A force that has an angular but no radial component?
Likes erobz
So ##\vec F=m\dot r\dot\theta\hat\theta##, right @flinnbella ?
Yes exactly. There is no radial force and the radial acceleration is zero
No its on the dependence of the radial velocity on the radial position.
It's on r dot dependence on r, not r double dot
It's difficult to know what is required, but if we take ##\frac d {dt} \dot r = \ddot r##, then that gives us a relationship between ##\dot r## and ##r##.
You should be able to make progress in any case, following the conventional approach in these problems (as I hinted at in the posts above).
You may recall ##\ddot x=\dot x\frac{d\dot x}{dx}##.
Likes erobz and PeroK
Behold the power of the Chain Rule!
Wow, I figured it out, thank you
Likes erobz
Thanks! but I’ll forward that to the providers of the key insights @PeroK , @haruspex
Likes hutchphd
FAQ: Particle experiencing only an angular force, determine the r dot
What is the meaning of r dot in the context of a particle experiencing only an angular force?
r dot (denoted as \( \dot{r} \)) represents the radial velocity of the particle, which is the rate of change of the particle's distance from a fixed point (usually the origin) with respect to time.
How do you determine r dot for a particle under only an angular force?
To determine \( \dot{r} \) for a particle experiencing only an angular force, you typically need to analyze the dynamics of the system using the equations of motion. Since the force is purely angular, the radial component of the force is zero. This often implies that the radial velocity \( \dot{r} \) could be constant or determined by initial conditions and conservation laws such as conservation of angular momentum.
What role does angular momentum play in determining r dot?
Angular momentum is crucial in determining \( \dot{r} \). For a particle under only an angular force, the angular momentum \( L \) is conserved. This conservation provides a relationship between the radial distance \( r \) and the angular velocity \( \dot{\theta} \). Knowing \( L \) and the functional form of \( r \), one can derive \( \dot{r} \) using the conservation laws.
Can r dot be zero for a particle experiencing only an angular force?
Yes, \( \dot{r} \) can be zero if the particle maintains a constant distance from the origin. This situation occurs when the particle moves in a perfect circular path, implying that all the force components are perpendicular to the radial direction, and hence do not change the radial distance.
How does the initial condition of the particle affect the determination of r dot?
The initial conditions, such as the initial radial distance \( r_0 \) and initial radial velocity \( \dot{r}_0 \), play a significant role in determining \( \dot{r} \). These conditions, along with the conservation laws and the specific form of the angular force, will dictate the evolution of the radial velocity over time.
