Particle free to slide along a frictionless rotating curve
In summary, the problem involves finding the equation of motion for a particle of mass m moving along a frictionless curve that is rotating about the y-axis at a constant angular speed ω. The particle is also subject to a uniform gravitational field of strength g acting along the negative y direction. Two different solutions using Newtonian and Lagrangian approaches are presented, with a discrepancy in the right-most term in the E-L equation being addressed and resolved.
Nathanael
1,650
246
A particle (of mass m) is free to move along a frictionless curve y(x) which is rotating about the y-axis at a constant angular speed ω. A uniform gravitational field (of strength g) acts along the negative y direction. Find the equation of motion of the particle.
(That's not the entire problem, but it's enough to explain the discrepancy I'm coming across.)
##y'\equiv \frac{dy}{dx}##
3. The attempt at a Newtonian Solution:
This picture should help explain the force equation:
The net force along the curve is due to gravity, namely ##mg\sin(\tan^{-1}(y'))=\frac{mgy'}{\sqrt{1+y'^2}}##
This has to account for the net acceleration in this direction, which comes from two things; the component of xω2 along the curve, and dv/dt the time derivative of the speed of the particle.
Since ##v=\frac{\dot x}{\cos(\tan^{-1}(y'))}=\dot x\sqrt{1+y'^2}## we have ##\dot v = \ddot x\sqrt{1+y'^2}+\frac{\dot x\dot y' y'}{\sqrt{1+y'^2}}##
Therefore the net-force equation in the direction along the curve is:
##\frac{mgy'}{\sqrt{1+y'^2}}=\frac{x\omega ^2}{\sqrt{1+y'^2}}-\big ( \ddot x\sqrt{1+y'^2}+\frac{\dot x\dot y' y'}{\sqrt{1+y'^2}} \big ) ##
Which can be written a little more nicely:
##x\omega^2-gy'=\ddot x(1+y'^2)+\dot x \dot y'y'##
4. The attempt at a Lagrangian Solution:
For the Lagrangian, I get ##L=\frac{m}{2}(x^2\omega^2+v^2)-mgy##
Where v is the speed as before: ##v=\frac{\dot x}{\cos(\tan^{-1}(y'))}=\dot x\sqrt{1+y'^2}##
So ##L=\frac{m}{2}(x^2\omega^2+\dot x^2(1+y'^2))-mgy##
Then the E-L equation gives:
##\frac{ \partial L}{\partial x}=m(\omega^2x-gy')=\frac{d}{dt}\big (\frac{ \partial L}{\partial \dot x} \big ) = \frac{d}{dt}\big ( m\dot x(1+y'^2)\big ) =m\big (\ddot x(1+y'^2)+2\dot x \dot y' y' \big )##
##x\omega^2-gy'=x(1+y'^2)+2\dot x \dot y' y'##
The right-most term differs by a factor of 2 from the Newtonian method. I can't seem to find the reason for this discrepancy; the force equation seems right to me.
In the E-L approach, did you take into account that ##y'## is a function of ##x##?
Likes Nathanael
Ohh, so it should have been: ##\frac{ \partial L}{\partial x}=m(\omega^2x-gy'+\dot x^2y'y'')##
Then by the chain rule: ## \dot x y''=\dot y'##
Thus: ##\frac{ \partial L}{\partial x}=m(\omega^2x-gy'+\dot x\dot y'y')##
Which leaves the equation the same as in the Newtonian approach.
I'm used to the discrepancy being due to a mistake in the Newtonian approach... Now I know to be careful with the E-L approach too! Thanks TSny!
Looks good.
Even though they are equivalent, I like the form ##\dot x^2y'y''## rather than ##\dot x\dot y'y'## because ##y'y''## is just a function of ##x## that you can easily get from the curve ##y(x)##.
Related to Particle free to slide along a frictionless rotating curve
1. What is a particle free to slide along a frictionless rotating curve?
A particle free to slide along a frictionless rotating curve refers to a hypothetical scenario in which a small object is placed on a curved surface that is rotating with no friction. The object is able to move freely along the curve without any external forces acting on it.
2. How is a frictionless rotating curve created?
A frictionless rotating curve is a theoretical concept and cannot be created in the physical world. It is often used in physics problems to simplify the analysis of motion on a curved surface.
3. What is the significance of studying particle motion on a frictionless rotating curve?
Studying particle motion on a frictionless rotating curve allows scientists to understand the effects of rotational motion and centripetal force on objects. It also helps in analyzing and predicting the behavior of objects in circular motion.
4. Can a real-world object move on a frictionless rotating curve?
No, a real-world object cannot move on a frictionless rotating curve as there will always be some form of friction present. However, scientists can create a similar scenario in a controlled environment using specialized equipment.
5. How does the absence of friction affect the motion of a particle on a rotating curve?
The absence of friction allows the particle to move without any resistance, resulting in a smooth and continuous motion along the curve. This allows scientists to isolate the effects of other forces, such as centripetal force, on the object's motion.
