Particle in an infinite square well
So you're basically decomposing the initial wave function into its stationary states (as you should be able to do with any function, so long as it's square integrable and satisfies the boundary conditions).In summary, the conversation discusses a point particle of mass m contained between two impenetrable walls with a potential of zero. The state of the particle at time t=0 is described by a wave function and the problem asks for normalization and the expectation value of the Hamiltonian. The conversation also mentions the possibility of a measurement of the energy of the particle and the calculation of the probability of finding the particle in the ground state of the well. The conversation also discusses the calculation of energies for a wider well and the decomposition of the initial
KaiserBrandon
54
Consider a point particle of mass m contained between two impenetrable walls at +/- 2a. The potential V(x) between the walls is zero. Assume that at time t=0 the state of the particle is described by the wave function
[tex]\Psi(x) = A\frac{1+cos(\frac{2*\pi*x}{a})}{2} for |x|\leq a/2[/tex]
=0 otherwise
a)normalize the wave function
b) Using configuration space, calculate the expectation value of the hamiltonian.
c) If a precise measurement of the energy of that particle were made, what would be the possible outcomes?
d)calculate the probability of finding the particle in the ground state of this well.
the postulates of quantum mechanics and the mathematics of quantum mechanics.
a)Normalizing the wave-function, I got
[tex]A=\sqrt{\frac{8}{3a}}[/tex]
b) I calculated the expectation value to be
[tex]<H> = \frac{2\hbar^{2}\pi^{2}}{3ma^{2}}[/tex]
c) Now this is the part I'm confused about. According to postulate 4, any precise measurement of the energy has a possible result of one of the eigenvalues of the operator H, correct? so then if we have,
[tex]H\Psi=E\Psi[/tex]
where
[tex]H=\frac{-\hbar^{2}}{2m}\frac{d^{2}}{dx^{2}}[/tex]
since V=0 inside the well, and E is the eigenvalue.
So then the eigenvalue I get is
[tex] E=\frac{\hbar^{2}*(2 \pi)^{2}*cos(\frac{2\pi x}{a})}{4ma^{2}*(1+cos(\frac{2 \pi x}{a})}[/tex]
but this would mean that E approaches infinity as x approaches +/- a/2.
The energy eigenvalues should not depend on x.
Note that the wave function is given at t=0. Start from a time-dependent wave function by multipliying with an exponential function depending on Omega t. Plugging into the time-dependent Schrödinger equation should give you the dispersion relation (energy as function of wave vector).
I would follow the steps described here for the infinite square well potential:
http://en.wikipedia.org/wiki/Particle_in_a_box
ok, so doing that I just get
[tex]E_{n}=\hbar \omega_{n}[/tex]
For this question though, it seems like the prof keeps specifying that we are just considering the initial wave function at time t=0. For the next part, we're supposed to consider if the well is doubled in width, and find the energies under these circumstances. When I asked him, he said that the calculations will be different for the wider well, even if you are analyzing the exact same wavefunction at time t=0. This just doesn't seem to make any sense to me whatsoever.
I don't know how you got your answers, but the standard way of solving this type of problem is:
1) Use the time-independent Schrodinger's equation to find the stationary states. Normalize them (this should be easy for the infinite square well).
2) Apply boundary conditions. Here, you know that the wavefunction has to be 0 at both ends of the well. These boundary conditions give you the possible energies corresponding to the stationary states.
3) Represent the initial wavefunction as a sum of the normalized stationary states. Suppose the coefficient of the nth stationary state is c_n. When you make a measurement on the particle, there is a probability of p=|c_n|^2 that the wavefunction would collapse into the nth stationary state. Hence, there is a p=|c_n|^2 chance that you'll measure E_n as your energy.
For your question about doubling the well: the answers will indeed be different. For the expanded well, you know that the wavefunction is 0 from x=a to x=2a. For the initial well, the region from x=a to x=2a had V=infinity, so for the purposes of finding the wavefunction inside the well it was irrelevant.
ok, so just treating this as an infinite square well problem, I get
[tex] E_{n}=\frac{\hbar^{2}}{2m}\frac{(n-1/2)\pi}{2a}[/tex]
and
[tex]\Psi_{n}=A_{n}cos(\frac{(n-1/2)\pi}{2a}x) A_{n}=\sqrt{\frac{1}{2a}}[/tex]
now when you say represent the initial wave function as a superposition of the stationary states, are you saying we represent the function at t=0 that is given in the question as a superposition of the states?
and
No, those aren't correct. This question is much easier to solve algebraically if you shift the reference frame so that the boundaries of the well are x=0 and x=4a. That way, you can use the well-known solution of the infinite square well. The possible energies remain unchanged (it would be quite surprising if they didn't, since all we did was redefine the coordinates). The eigenfunctions are simply shifted by 2a.
I'm saying represent the initial wave function as such. Of course, the initial wave function is just the function given, plus 0 for the two "sides" (x<-a/2 and x>a/2).
FAQ: Particle in an infinite square well
What is a particle in an infinite square well?
A particle in an infinite square well is a theoretical model used in quantum mechanics to describe the behavior of a particle confined to a one-dimensional space with infinite potential energy at the boundaries.
What are the properties of a particle in an infinite square well?
The main properties of a particle in an infinite square well include a discrete energy spectrum, quantized energy levels, and a probability distribution that decreases to zero at the boundaries of the well.
How is a particle in an infinite square well different from a free particle?
A free particle has no potential energy and can move freely in all directions, while a particle in an infinite square well is confined to a specific region and has a quantized energy spectrum. Additionally, the wave function of a particle in an infinite square well is zero at the boundaries, while a free particle's wave function can extend to infinity.
What is the significance of the infinite potential energy in an infinite square well?
The infinite potential energy at the boundaries of an infinite square well represents an idealized situation where a particle is completely confined. This helps to simplify the mathematical calculations and makes it easier to study the behavior of quantum systems.
How is a particle in an infinite square well related to real-world systems?
A particle in an infinite square well is a simplified model used in quantum mechanics to better understand the behavior of particles in more complex systems. It can be used to study the behavior of electrons in atoms and molecules, as well as the behavior of particles in solid-state materials.
