Particle in free space - what happens to the wave function after measurement?
In summary, when trying to solve for a particle in free space with the Hamiltonian H=P^2/2m, the eigenfunctions cannot be normalized. However, if a legitimate wave function is expressed in terms of the eigenfunctions of H, the resulting energy measurement will depend on the specific interaction with the measurement device. The energy eigenstates for a free particle are not square-integrable, but true states can be approximated with square-integrable wave functions. The position uncertainty will increase with time, while the Heisenberg uncertainty relation always holds. To measure the energy of a free particle, its momentum must be measured, which will result in an increase in position uncertainty.
QuasarBoy543298
32
If I'm trying to solve the problem of a particle in free space (H = P2/2m ).
the eigenfunctions of the Hamiltonian cannot be normalized.
now assume I have a legitimate wave function expressed in terms of the eigenfunction of H and I want to measure its energy.
what will happen to the wavefunction after the measurement?
You cannot say this without telling which specific measurement device you use. What happens depends on the specific interaction of the measured system with the measurement device.
In your case of the free particle, you should note that there are no energy eigenstates in the literal sense, because the energy eigenstates are uniquely given by the common eigenstates of thee three momentum components, and these are plane waves. They are not square-integrable and thus belong not to the Hilbert space (in wave mechanics the space of square-integrable functions) but to the dual of the nuclear space, where position and momentum operators are defined, i.e., they are distributions.
True states, coming close to energy eigenstates are square-integrable wave functions which peak quite sharply in momentum space. You can, e.g., choose a Gaussian ##\tilde{\psi}_0(\vec{p}) \propto \exp[-(\vec{p}-\vec{p}_0)^2/(4 \sigma_p)]## as an initial state. Then the solution of the Schrödinger equation in momentum space simply is
$$\tilde{\psi}(t,\vec{p})=\exp \left (-\frac{\mathrm{i} \vec{p}^2}{2m \hbar} t \right) \tilde{\psi}_0(\vec{p}).$$
The position representation then follows by Fourier transformation
$$\psi(t,\vec{x})= \frac{1}{\sqrt{2 \pi \hbar}} \int_{\mathbb{R}^3} \mathrm{d}^3 p \tilde{\psi}(t,\vec{x}),$$
which is again a Gaussian, which now however is rather broad, and the position uncertainty increases with time.
Always the Heisenberg uncertainty relation holds,
$$\Delta x_j \Delta p_j \geq \hbar/2$$
for each position-vector and momentum component, ##j \in \{1,2,3\}##.
Likes Heikki Tuuri
To measure the energy of a free particle, you have to measure its momentum p. If you describe the particle with a wave packet, and want to improve your knowledge of the momentum p of the particle, then the uncertainty in the location of the particle has to grow. The wave packet becomes wider.
Related to Particle in free space - what happens to the wave function after measurement?
1. What is a particle in free space?
A particle in free space refers to a single particle that is not influenced by any external forces or interactions. It is essentially isolated and can move freely without any constraints.
2. What is the wave function of a particle in free space?
The wave function of a particle in free space is a mathematical representation of the probability amplitude of the particle's position and momentum. It describes the probability of finding the particle at a particular location or with a particular momentum.
3. What happens to the wave function after measurement?
After measurement, the wave function collapses into a specific state, which corresponds to the observed measurement. This means that the particle's position and momentum become definite and no longer described by a probability distribution.
4. Can the wave function of a particle in free space be predicted?
No, according to the principles of quantum mechanics, the wave function of a particle in free space cannot be predicted with certainty. It can only be described by a probability distribution.
5. How does the wave function of a particle in free space change over time?
The wave function of a particle in free space evolves over time according to the Schrödinger equation, which describes how the wave function changes in response to the particle's energy. This evolution can be observed through measurements, which cause the wave function to collapse into a specific state.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
