Particle movement in a non-static magnetic field
In summary, the conversation discusses the use of equations to calculate the movement of particles in two coupled coils. The general equation for particles is given, but the conversation then delves into the use of magnetic flux conservation and Lorentz equation to calculate particle movement. A modified equation is also proposed, but it is noted that it is only accurate for slow varying magnetic fields.
Javier Lopez
75
Particles follows accordingly the general equation:
m*\overrightarrow{a}=q*\overrightarrow{E}+q*\overrightarrow{v}\wedge \overrightarrow{B}
But in the case of two coupled coils the time varying current at primary coil (and its magnetic field variation) creates corresponding varying current in the secondary coil
To calculate it I use the magnetic flux conservation like in transforrmers where the plasma is the secondary coil but it does not work well to calculate the movement of each particle
Then, what formula is better to use to calculate the particle movement?
Accordingly Lorentz applied to a loop (where the ion describes a circled current):
Fem=\oint \overrightarrow{E}\overrightarrow{dl}=-\frac{d\overrightarrow{\phi }}{dt}\\\\
2\pi r*\overrightarrow{E}=-\pi r^2*\frac{d\overrightarrow{B}}{dt}\\\\
\overrightarrow{E}=-0.5*r*\frac{d\overrightarrow{B}}{dt}
So:
m*\overrightarrow{a}=q*\overrightarrow{E}+q*\overrightarrow{v}\wedge \overrightarrow{B} - \frac{1}{2}*q*r* \frac{d\overrightarrow{B}}{dt}
Where r is the Cyclotron radius. That is only true for slow varying magnetc fields because the ion does not describes a circle but an helix
Is it correct?
Fun question, but unfortunately, for other reasons this user will not be returning to the PF. Thread is closed.
Related to Particle movement in a non-static magnetic field
1. How does a non-static magnetic field affect particle movement?
A non-static magnetic field can exert a force on a charged particle, causing it to move in a circular or helical path. This is known as the Lorentz force and is dependent on the strength and direction of the magnetic field, as well as the charge and velocity of the particle.
2. What is the difference between a static and non-static magnetic field?
A static magnetic field is one that does not change in strength or direction, while a non-static magnetic field is one that is changing over time. This can be due to the movement of the magnetic source or the presence of other magnetic fields.
3. How do particles behave in a non-static magnetic field?
Particles in a non-static magnetic field will experience a force that is perpendicular to both the velocity of the particle and the direction of the magnetic field. This force will cause the particle to move in a curved path, with the radius of the curve depending on the strength and direction of the magnetic field, as well as the speed of the particle.
4. What is the significance of particle movement in a non-static magnetic field?
Understanding particle movement in a non-static magnetic field is important in many areas of science and technology. It is used in particle accelerators, magnetic resonance imaging (MRI) machines, and in the study of plasma and astrophysics.
5. How can the movement of particles in a non-static magnetic field be controlled?
The movement of particles in a non-static magnetic field can be controlled by adjusting the strength and direction of the magnetic field. This can be done using electromagnets or by changing the position of the magnetic source. Additionally, the properties of the particles themselves, such as their charge and velocity, can also be manipulated to control their movement in a magnetic field.
  • Atomic and Condensed Matter
  • Electromagnetism
