Particle moving along a parabola
In summary, the conversation discusses the displacement equation s=0.5t^2 and its relationship to velocity and acceleration. Part I of the conversation determines the direction and components of the velocity and acceleration vectors at an arbitrary point on the graph. Part II introduces a different equation for the x-component of velocity, but there is not enough information given to determine the particle's speed. Further clarification is needed for Part II.
Peppino
39
Can someone please check that everything I have done so far is correct?
A particle movies along a parabola with the displacement equation s = 0.5t2.
(a graph is shown)
::::Part I::::
Suppose x-component is s = Ct
i) indicate direction of velocity vector and acceleration at point R (arbitrary point on graph)
ii) Determine y-component of particles velocity
iii) Determine y-component of particles acceleration
Answers:
i) I suppose the velocity vector would be tangential to the graph and the acceleration vector would be parallel with the y-axis?
ii) since V = √(Vx2 + Vy2), and V = t, I found that the y - component is √(t2-C2t2).
iii) Since the acceleration is constant, is the y-component simply C?
:::Part II::::
Suppose instead that the x-component of the velocity is given by [tex]\frac{C}{\sqrt{1 + t^{2}}}[/tex]
i) Show that the particle's speed is constant
I am unsure how to attempt Part II.
If you are able to answer or confirm my answers to any part of this question, thank you very much!
Some help would be greatly appreciated!
We need some explanation. What is s? I do not see the graph.
ehild
For part (i) - you are right,
For part (ii) you have used s_x instead of V_x to determine V_y
For part (iii) - yes, the acceleration is constant, but it is not equal to C; but maybe try determining the total acceleration, and the acceleration in the x direction instead of differentiating...
- if you typo'd s=Ct; and it's actually V_x=Ct, then your answer to part (i) is wrong, part (ii) is right and you still need to determine part (iii) - it's a constant still, but not C
For part (II)
there isn't enoguh information - is the total motion of the particle still given by s=.5t^2?
Because in that case, the particles speed can't be constant - it's speed is, as you said, is equal to t, which is a variable.
Was there any other information?
s=0.5t^2 is a scalar equation. If s is displacement, the particle moves along a straight line, not along a parabola. If a particle moves along a parabola, you need to give the relation between its coordinates. Can you show the original text of the problem?
ehild
FAQ: Particle moving along a parabola
What is a particle moving along a parabola?
A particle moving along a parabola refers to a point or object that follows a curved path described by a parabola curve. This motion is typically described using physics equations such as position, velocity, and acceleration.
What factors affect the motion of a particle along a parabola?
The motion of a particle along a parabola is affected by factors such as initial velocity, angle of projection, and the force acting on the particle. Other factors that can influence the motion include air resistance, friction, and external forces like gravity.
How is the motion of a particle along a parabola calculated?
The motion of a particle along a parabola can be calculated using equations such as the parabolic motion equation or equations of motion. These equations take into account factors such as initial velocity, acceleration, and time to determine the position, velocity, and acceleration of the particle at any given point along the parabola.
What is the significance of a particle moving along a parabola in physics?
The motion of a particle along a parabola has significant implications in physics as it can be used to describe the motion of objects under the influence of gravity. It is also used to study the effects of air resistance, friction, and other forces on the motion of objects in real-world scenarios.
What are some real-life examples of a particle moving along a parabola?
Some common real-life examples of a particle moving along a parabola include a ball being thrown, a projectile being launched, or a rollercoaster moving along its track. These motions can be described using equations of motion and parabolic motion equations.
