Particle moving with radial velocity
In summary, the particle has a constant radial velocity of 4m/s and a constant angular velocity of 2rad/s. When the particle is 3m from the origin, the magnitude of its velocity is 6m/s. To find the final velocity, you can use vector addition. Alternatively, you can use the normal polar equations for velocity and acceleration. The acceleration in this case is zero. To find the acceleration, you can use the equation a=v\Theta/(1-cos\Theta).
aigerimzh
A particle moves in a plane with constant radial r=4m/s. The angular velocity is constant and has magnitude [itex]\Theta[/itex]=2rad/s. When the particle is 3m from the origin, find the magnitude of the velocity and the acceleration.
The answer is v=root of 52 m/s. But I don't know how to get this number. Can somebody give me a hint?
Radial velocity is constant at 4m/s.So when its 3m from origin,the tangential component of velocity is given by v=omega X r, ie 6m/s in this case
Now you have the mutually perpendicular radial and tangential components as 4m/s and 6m/s,calculate the final velocity by vector addition.
As an alternative to calculate speed and acceleration in Cartesian coordinates you may also want to find inspiration in the normal polar equations for velocity and acceleration, see for instance [1]. These equations are more general as they also allow for radial and angular accelerations, but in your case those are zero and inserting that you end up with two simple vector equations to take magnitude of.
[1] http://en.wikipedia.org/wiki/Polar_coordinate_system#Vector_calculus
Can I find acceleration by a=v[itex]\Theta[/itex]/(1-cos[itex]\Theta[/itex]t)?
Can somebody answer me?
FAQ: Particle moving with radial velocity
What is a particle moving with radial velocity?
A particle moving with radial velocity is a type of motion in which the particle moves along a circular path, with its velocity always directed towards the center of the circle.
How is the radial velocity of a particle calculated?
The radial velocity of a particle can be calculated by taking the dot product of the particle's velocity vector and the unit vector pointing towards the center of the circle.
What factors affect the radial velocity of a particle?
The radial velocity of a particle is affected by the particle's speed, the radius of the circular path, and the angle at which the particle is moving relative to the center of the circle.
Can a particle have a constant radial velocity?
No, a particle cannot have a constant radial velocity as it is always changing direction towards the center of the circle.
How is the radial acceleration of a particle related to its radial velocity?
The radial acceleration of a particle is directly related to its radial velocity, as it is the rate of change of the radial velocity. A higher radial velocity will result in a higher radial acceleration.
