I Particle on a cylinder with harmonic oscillator along z-axis
Salmone
I need to know if I have solved the following problem well:
A spin-less particle of mass m is confined to move on the surface of a cylinder of infinite height with a harmonic potential on the z-axis and Hamiltonian ##H=\frac{p_z^2}{2m}+\frac{L_z^2}{2mR^2}+\frac{1}{2}m\omega^2z^2## and I need to calculate its eigenvalues and eigenvectors.
I thought of separating the Hamiltonian as it is written in the text, and find the Hamiltonian of a particle on a ring and a harmonic oscillator along the z-axis with eigenfunctions of the type ##|\psi\rangle=|m\rangle|n\rangle## where ##m## are the eigenvalues of ##L_z## equal to ##\frac{1}{\sqrt{2\pi}}e^{im\phi}## and ##n## are the eigenvalues of the harmonic oscillator. For the eigenvalues I had thought they were ##E=\frac{n^2\hbar^2}{2mR^2}+\hbar\omega(n+1/2)##. Is this right?
Also, if I had a perturbation like ##\epsilon cos(\phi)## to calculate on the fundamental level I could say by eye that its effect is zero since in the fundamental level there is no angular momentum?
You have to write ##\mu## for the mass to distnguish if from the eigenvalue of ##\hat{L}_z##, ##m \hbar##. Then ##E_{mn}=m^2\hbar^2/(2\mu R^2)+\hbar \omega (n+1/2)##, where ##m \in \mathbb{Z}##, ##n \in \mathbb{N}_0##.
Thank you @vanhees71 for the answer, so the eigenvalues are correct, what about the total Hamiltonian eigenvectors? Are they correct? And the perturbation?
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
