Particle's Equation, Velocity and Acceleration
In summary, you need to find an equation of the form ##y = F(x)## or ##x = G(y)## or ##H(x,y) = 0##, where ##F## or ##G## or ##H## are the functions that represent the curve of the orbit.
defaultusername
r(t) is the position of a particle in the xy-plane at time t. Find an equation in x and y whose graph is the path of the particle. Then find the particle’s velocity and acceleration vectors at the given value of t.
First derivative = velocity
(velocity=distance/time)
Second derivative = acceleration
(acceleration=velocity/time)
To find the Equation, I first organize it into a set:
[ et, 2/9 e2t ]
Then I just plug in the value of t (ln3)
[ eln3, 2/9 e2(ln3) ]
I then reconstruct the original problem with the new values:
r(t) = eln3 i + 2/9 e2(ln3) j
r(ln3) = e1.0986 i + 2/9 e2.1972 j
then I change the i / j to x/y
r(ln3) = e1.0986 x + 2/9 e2.1972 y
As for velocity and acceleration, so far I have figured it like this:
Velocity:
[ et, 2/9 e2t ]
[ te, 4/9 et ]
Velocity = tei + 4/9etj
Acceleration:
[ e, 4/9 te]
Acceleration = tei + 4/9 tej
Am I taking the derivative correctly? As far as I know, e remains as e, even after the derivative, right?
thanks in advance
[ et, 2/9 e2t ]
Velocity:
[ et, 2/9 e2t ]
[ te, 4/9 et ]
Acceleration:
[ e, 4/9 te]
thanks in advance
For the derivatives of et, you should review the rules of differentiation for such functions and not neglect application of the chain rule.
http://www.themathpage.com/acalc/exponential.htm
Remember, et is not differentiated like xn.
You have not done the second part, which says "Find an equation in x and y whose graph is the path of the particle". This means that instead of representing the particle's orbit as ##(x(t),y(t))## you should represent the curve of the orbit (not including "time" information) as an equation of the form ##y = F(x)## or ##x = G(y)## or ##H(x,y) = 0##, and you are to figure out the functions ##F## or ##G## or ##H##, as needed.
Got it! Thanks for your guys' help!
FAQ: Particle's Equation, Velocity and Acceleration
What is the equation for calculating the velocity of a particle?
The equation for calculating the velocity of a particle is v = d/t, where v is the velocity, d is the distance traveled, and t is the time taken to travel that distance.
How is acceleration related to velocity?
Acceleration is the rate of change of velocity. This means that an object's acceleration is directly proportional to its change in velocity over a certain period of time.
How do you calculate the acceleration of a particle?
The equation for calculating acceleration is a = (vf-vi)/t, where a is the acceleration, vf is the final velocity, vi is the initial velocity, and t is the time taken.
What is the difference between constant and variable acceleration?
Constant acceleration is when the rate of change of velocity remains the same over time, while variable acceleration is when the rate of change of velocity is not constant and may change over time.
Can a particle have a constant velocity and still have acceleration?
No, a particle cannot have a constant velocity and still have acceleration. Acceleration is the change in velocity over time, so if the velocity is constant, the acceleration will be zero.
