Particle's maximum height in liquid
In summary, the particle reaches its highest point ymax when it has a speed of v0 and a drag force of Fd=m*a*v.
fullerene
I'm not sure if this is the appropriate subforum, but here it goes:
Suppose you have a particle, with the mass m, at the bottom of jar which is filled with liquid. The particle is shot upwards, parallel to the gravitational force, with the speed v0. The drag force is proportional to the particle's speed. What is the maximum height ymax of the particle?
First, "down"force equals to:
Ft=W+Fd
m*a=m*g+b*v
=> a(v)=g+(b/m)v
v(t)=v0+a*t, at ymax: v(t)=0
=> 0=v0+a*t
With cross subtituting, I cannot eliminate the variables v or t from the ymax function. Somehow I think the ymax function should not depend on the v or t variables, but maybe I'm wrong. Can you guys help me?
Thanks!
i think it should be:
Ft-W-Fd=ma
where Ft is force that needed to shoot the particle.
Hmm... I think that the force to shoot the projectile is irrelevant because the projectile has experienced the accelerating process and the force that "shoot" the projectile is no longer acting on it. I dunno, maybe I'm wrong.
Btw, when we consider that this experiment is done in vacumm, the ymax function is obtainable rather easily, just use y(t)=v0*t+(1/2)*g*(t^2). The value of t can be obtainable using v(t)=v0+g*t, which v(t) is zero (at ymax). Then ymax is just a function of v0 -> ymax(v0)=a*v0+b.
i think you can use here energies:
[tex]K_{h}-K_{v_0}=mgh+bv^2/2[/tex]
and the fact that: h=(v^2-v0^2)/2g (also known as galileo equation).
but I am not sure about the rhs of the first equation.
Since a= dv/dt and depends on v, you can't solve that algebrically. You have a differential equation:
[tex]\frac{dv}{dt}= -g- \frac{bv}{m}[/itex]
That's relatively simple "non-homogeneous linear differential equation with constant coefficients".
Ok, thanks HallsofIvy and loop_quantum_gravity.
FAQ: Particle's maximum height in liquid
What is a particle's maximum height in liquid?
A particle's maximum height in liquid refers to the highest point that a particle can reach while submerged in a liquid. This height is influenced by factors such as the density of the liquid, the size and shape of the particle, and the forces acting on the particle.
How is a particle's maximum height in liquid measured?
A particle's maximum height in liquid is typically measured by observing the particle's movement and tracking the highest point it reaches while submerged in the liquid. This can be done using specialized equipment such as a high-speed camera or by conducting experiments and recording the results.
What factors affect a particle's maximum height in liquid?
The main factors that affect a particle's maximum height in liquid include the density of the liquid, the size and shape of the particle, and the forces acting on the particle. For example, a denser liquid will exert more buoyant force on the particle, allowing it to reach a higher maximum height.
Can a particle's maximum height in liquid be greater than its size?
Yes, a particle's maximum height in liquid can be greater than its size. This is due to the buoyant force exerted by the liquid, which can cause the particle to rise higher than its own size. This phenomenon is commonly observed in small particles, such as dust, submerged in water.
How does the shape of a particle affect its maximum height in liquid?
The shape of a particle can greatly affect its maximum height in liquid. A more streamlined shape, such as a sphere, will experience less resistance from the liquid and can reach a higher maximum height compared to a more irregularly shaped particle. Additionally, the shape can also impact the buoyant force exerted on the particle, further influencing its maximum height.
