Particular Solution of A Coupled and Driven Oscillator
In summary: You should end up with a 4x4 matrix equation whose determinant is 0. That will give you two of the four frequencies as ##2\omega## and ##\sqrt{3}\omega##. The others will involve imaginary numbers.
PatsyTy
30
Consider two masses m connected to each other and two walls by three springs with spring constant k. The left mass is subject to a driving force ## F_d\cos(2 \omega t) ## and the right to ## 2F_d\cos(2 \omega t) ##
Writing out the coupled equations:
$$ m_1 x_1''+2kx_1-kx_1 = F_d \cos (2\omega t) $$
$$ m_2 x_2''-kx_1+2kx_2 = 2F_d\cos (2 \omega t) $$
[/B]
Assume a solution
$$ x_1 = A_1 \cos (\omega t) \rightarrow x_1'' = -A_1 \omega^2 \cos (\omega t) $$
$$ x_2 = A_2 \cos (\omega t) \rightarrow x_2'' = -A_2 \omega^2 \cos (\omega t) $$
Sub this into our original equation and write it as a matrix equation
$$ -\omega^2 \cos (\omega t) \left( \begin{array}{c} A_1 \\ A_2 \end{array} \right) + \omega^2 \left( \begin{array}{cc} 2 & -1 \\ -1 & 2 \end{array} \right) \left( \begin{array}{c} x_1 \\ x_2 \end{array} \right) = \frac{F_d}{m} \cos (2 \omega t) \left( \begin{array}{c} 1 \\ 2 \end{array} \right) $$
where ##\omega^2 = k/m ##. This is where I get stuck, before we would form an eignevalue problem and solve the characteristic polynomial to get the eigenvalues then the constants ##A_1## and ##A_2## however we have too many terms to do this.
A suggestion on where to go from here would be greatly appreciated!
The frequency ω in the driving forces is not necessarily equal to ##\sqrt{k/m}##. You should use another notation, such as ##\omega_0^2 = k/m##.
Since the driving forces have frequency ##2 \omega##, you might be better off with a trial solution where ##x_1## and ##x_2## vary with frequency ##2 \omega##.
Thanks for the reply! That was my bad actually in copying the question, it does specify in the problem that the frequency of the driving for is equal to ##\sqrt{k/m}##. I believe I managed to get the solution after a couple hours of work by adding the two equations and subtracting the two equations and making a substitution of variables:
Adding the Two
$$(x_1''+x_2'')+\omega^2(x_1+x_2)=\frac{3F_d}{m} \cos (2 \omega t) $$
Set ##z=x_1+x_2 \rightarrow z''=x_1''+x_2''##
Gives
$$z''+\omega^2 z = \frac{3F_d}{m} \cos (2 \omega t)$$
Similar argument for subtracting the two. Is it possible to solve this question using a matrix equation? I don't see any simple way of doing so but may not be seeing it.
Otherwise thanks for the help!
Yes. Proceed as in your first post, but assume ##x_1## and ##x_2## vary as ##\cos2\omega t##.
Likes PatsyTy
Related to Particular Solution of A Coupled and Driven Oscillator
1. What is a coupled and driven oscillator?
A coupled and driven oscillator is a physical system that consists of two or more oscillators that are connected or coupled to each other, and are also influenced by an external driving force. Examples of coupled and driven oscillators include pendulums, springs and masses, and electronic circuits.
2. What is a particular solution of a coupled and driven oscillator?
A particular solution of a coupled and driven oscillator refers to a specific solution that satisfies the given initial conditions and boundary conditions for the system. It is a unique solution that describes the behavior of the system at a particular moment in time.
3. How is a particular solution of a coupled and driven oscillator determined?
A particular solution of a coupled and driven oscillator is determined by solving the equations of motion that govern the behavior of the system. This involves using mathematical techniques such as differential equations, linear algebra, and Fourier analysis to find the specific values of the system's variables at a given time.
4. What factors affect the behavior of a coupled and driven oscillator?
The behavior of a coupled and driven oscillator is influenced by several factors, including the properties of the individual oscillators, the strength of the coupling between them, and the characteristics of the external driving force. Other factors such as damping, nonlinearity, and resonance can also play a role in the behavior of the system.
5. What are some real-world applications of coupled and driven oscillators?
Coupled and driven oscillators have numerous applications in various fields, including physics, engineering, and biology. They are used in the design of electronic circuits, control systems, and mechanical devices. They also play a role in understanding natural phenomena such as synchronization in fireflies and heartbeats, and resonance in musical instruments.
