Partition function of mixture of two gases
In summary, the question is about the total partition function of a system with two compartments in thermal contact, one of which has a permeable membrane for particles of gas A. The approach is to calculate the partition function of the system by considering a mixture of particles from compartment B and some particles from compartment A. However, this approach needs to be modified to account for the constraint of particles not mixing. The volume of ##Z(N_A^R)## would be ##V-N_A^R## and the partition function for compartment A would be ##Z_2=Z_1^{single}^{N_A^R}##.
millerm
TL;DR Summary
Determine the partition function of a mixture of 2 gases
I have a question about statistical physics. Suppose we have a closed container with two compartments, each with volume V , in thermal contact with a heat bath at temperature T, and we discuss the problem from the perspective of a canonic ensemble. At a certain moment the separating wall is replaced by a membrane that is permeable for particles of gas A, but not for particles of gas B. What is the total partition function of the final system as a function of ##N_A^R## ?
My approach was to first consider a mixture between the particles in container B, ##N_B## and some of the particles from container A, let's say ##N_A^R##, and calculate the partition function: ##Z_1=Z(N_B)Z(N_A^R)##. The partition function of compartment A is: ##Z_2=Z(N_A-N_A^R)##. And next take the partition function of two subsystems in contact with a thermal reservoir: ##Z_{tot}=Z_1Z_2##. Is this approach correct? If yes, what do you take for the volume of ##Z(N_A^R)## ?
I hope someone can help me with this.
Hello! Your approach is mostly correct, but there are a few things to consider.
First, the total partition function of the final system as a function of ##N_A^R## can be written as ##Z_{tot}=Z_1(N_B)Z_2(N_A-N_A^R)##, since the partition functions of the two subsystems are multiplied together.
Next, for the volume of ##Z(N_A^R)##, you can consider it as the volume of the compartment A that is now occupied by the particles of gas A. So, it would be ##V-N_A^R## since ##N_A^R## particles have been removed from the original volume V.
However, there is one more thing to consider. In your approach, you have assumed that the particles from compartment A are mixed with the particles from compartment B. But, in reality, the particles of gas A are only permeable through the membrane and will not mix with the particles of gas B. So, the partition function for compartment A should be modified to take into account this constraint. This can be done by considering the partition function of a single particle of gas A in compartment A, which would be ##Z_1^{single}=e^{-\beta \epsilon_A}##, where ##\epsilon_A## is the energy of a single particle of gas A. Then, the partition function for compartment A would be ##Z_2=Z_1^{single}^{N_A^R}##.
Overall, your approach is on the right track, but it would need some modifications to account for the constraint of the particles not mixing. I hope this helps!
FAQ: Partition function of mixture of two gases
What is the partition function of a mixture of two gases?
The partition function of a mixture of two gases is a mathematical concept used in statistical mechanics to describe the distribution of energy among the particles in the mixture. It takes into account the different energy levels and degeneracies of the particles in the mixture.
How is the partition function of a mixture of two gases calculated?
The partition function of a mixture of two gases is calculated by summing the partition functions of each individual gas in the mixture. This takes into account the different energy levels and degeneracies of the particles in each gas.
Why is the partition function of a mixture of two gases important?
The partition function of a mixture of two gases is important because it allows us to calculate thermodynamic properties of the mixture, such as the internal energy, entropy, and free energy. It also helps us understand the behavior of the mixture at different temperatures and pressures.
How does the partition function of a mixture of two gases change with temperature?
The partition function of a mixture of two gases increases with temperature, as more energy levels become available for the particles to occupy. This results in a higher probability of finding particles in higher energy states, leading to an increase in the overall partition function.
Can the partition function of a mixture of two gases be used to predict the behavior of real gases?
Yes, the partition function of a mixture of two gases can be used to predict the behavior of real gases, as long as the gas molecules behave according to the assumptions of the ideal gas law. However, for more complex systems, other factors such as intermolecular interactions may need to be taken into account.
