- 67,605
- 20,864
I'm working on an old test fixture that uses JTAG to program a microcontroller (uC) and its Flash memory chip on production PC Board Assemblies. The programming works fine with an old version of the PCBAs, but for some reason it is failing with a new version of the PCBA that should have had no changes to the JTAG connections, uC or Flash memory chip circuitry.
I'd like to passively monitor the JTAG programming stream to compare the passing and failing datastreams. Does anybody know a good tool or Pod or other way to do this? I've used an old HP logic analyzer in the past to do such probing for short datastreams, but the serial-to-parallel conversion is a bit of a pain for a vanilla tool without some formatting capability.
The JTAG programming Pod I'm using is the TI MSP-FETU430IF (and the Gang programming equivalent), and the uC is the TI MSP430F5437A with external serial Flash memory. I do have a TotalPhase Beagle SCI/SPI Serial Analyzer Pod available, if there is some way to adapt it to JTAG...
Thanks for any ideas.
https://msharmavikram.files.wordpress.com/2012/03/msp-fet430uif.jpg
