Patent the use of a material/section
  • Thread starter Mech King
  • Tags
    Patent
In summary, it is possible to patent the use of a certain steel section for a specific application, such as in a collapsible lift design. However, the patent would not be for the section itself, but for the application of that section in the design. The patent would need to be broad enough to cover any similar configurations that may be competitive. For example, in the case of a frangible disconnect for the rocket launching industry, the patent may cover a bolt with a specific geometry that allows for breakage at a specific force while still being strong enough in bending.
Mech King
73
Is it possible to patent the use of a certain steel section for a certain appication?
For example patenting the use of channel section for the use in a collapsable lift design?
I think you could. Any good patent has to be general enough to cover not just your specific configuration but any similar configuration which may be competitive. Your patent won't be a patent on the section, it will be a patent on the application of that section for your design. I would think the patent would be for the design first, with the section being essentially part of your first claim.
Take for example, a frangible disconnect for the rocket launching industry. The frangible portion of the disconnect breaks as the rocket rises, resulting in half the disconnect remaining on the rocket. To do this you may have bolts with a notch in them to allow for breakage at a specific, repeatable force. The same bolt may need to be strong in bending while being weak in tension, so your patent may cover a bolt that has a crack half way through it and the first claim would describe this geometry in as broad a sense as possible.
Thanks Q Goest,
That makes perfect sense. Thanks for your respsonse.
Many Thanks
Mech King
Related to Patent the use of a material/section
What is a patent for the use of a material or section?
A patent for the use of a material or section is a legal protection granted to the inventor of a new and useful material or section. It gives the inventor the exclusive right to use, sell, and profit from their invention for a certain period of time.
How do I know if my material or section is patentable?
In order for a material or section to be patentable, it must meet certain criteria, including being new, non-obvious, and useful. This means that it must be a novel invention that is not obvious to someone with ordinary skill in the field, and it must have a practical application.
What is the process for obtaining a patent for the use of a material or section?
The process for obtaining a patent for the use of a material or section involves filing a patent application with the appropriate patent office. This application must include a detailed description of the invention, including how it is used and its potential uses. The application will then go through a review process to determine if it meets the criteria for patentability.
How long does a patent for the use of a material or section last?
A patent for the use of a material or section typically lasts for 20 years from the date the patent application was filed. However, this can vary depending on the country and type of patent.
Are there any limitations to a patent for the use of a material or section?
Yes, there are limitations to a patent for the use of a material or section. For example, the patent only protects the specific use of the material or section as described in the patent application. Others may be able to use the same material or section for different purposes without infringing on the patent. Additionally, patents may also be subject to expiration or revocation if certain conditions are not met.
