kLPantera
- 43
Part 1
We fired a cannon 0 degrees to the horizontal line and had to calculate Vo. We then measured Delta x and Delta Y.
Part 2
We were then given a degree in which to fire the cannon at, which was 12 degrees. We then had to calculate the projectile's path through 3 rings and then hit a target.
We we used were what we got from part 2 (Vo, Delta x, and Delta y).
Data:
Delta y = -0.87m (from a counter top to the ground)
Calculated Data:
Vix = 4.02 m/s
Viy = 0.85 m/s
Vo = 4.11 m/s
Known Data:
ax = 0 (we are operating under the scenario that there is no air resistance)
ay = -9.8 m/s2
Delta y = Viyt + (1/2)gt2
Delta x = Vixt + (1/2)at2
Vfy = Viy + gt
Theta = tan-1 = (Viy/Vix)
First I calculated time:
-0.87 = (0.85)t + (1/2)(-9.8)t2
t = 0.5163 seconds ( I used quadratic formula)
Second I calculated Delta x:
Delta x = (4.02)(0.5153)
Delta x = 2.07
There are three rings placed at equal intervals throughout Delta x so:
x1 = 0.5175(ring 1)
x2 = 1.035 (ring 2)
x3 = 1.5525 (ring 3)
x4 = 2.07 (target)
Time to reach each target:
Ring 1: 0.129075 seconds
Ring 2: 0.25815 seconds
Ring 3: 0.387225 seconds
Target: 0.5163 seconds
Height of each ring:
Delta Y1 = (0.86)(0.129075) + (1/2)(-9.8)(0.129075)2 + 0.87 = 0.898
Delta Y2 = (0.86)(0.25815) + (1/2)(-9.8)(0.25815)2 + 0.87 = 0.76
Delta Y3 = (0.86)(0.387225) + (1/2)(-9.8)(0.387225)2 + 0.87 = 0.464
Delta Y4 = (0.86)(0.5163) + (1/2)(-9.8)(0.5163)2 + 0.87 = 0.008
Angle For Each Ring:
Ring 1: Vy = (-9.8)(0.129075) + 0.85 = -0.41493
theta = tan-1 = (0.41493/4.02) = 5.89 degrees
Ring 2: Vy = (-9.8)(0.25185) + 0.85 = -1.67987
theta = tan-1(1.67987/4.02) = 22.67 degrees
Ring 3: Vy = (-9.8)(0.387225) + 0.85 = -2.944805
theta = tan-1(2.944/4.02) = 36.21 degrees
With these calculations my lab group and I attempted to shoot through Ring 2 and hit the target. Our ring 2 fell short of the projectile, however the projectile still hti the target close to the bullseye. We also have to shoot through ring 3.
Could someone help?
Much Appreciated.
