Path of positivley charged particle in electric field
In summary: Knowing this, I used the right hand grip rule to figure it wouldn't just spiral in acircular clockwise path but in a helical anticlockwise path. Because the electric field is uniform, the particle will follow a helical path in an anticlockwise direction.
ghostbuster25
102
A positivley charged particle is traveling in a straight line with velocity v at a small angle from the horizontal.
At a certain instant a constant uniform electrical field is applied in the downward vertical.
what is the direction of the charged particle?
I figured that the equation for a particle in a electric field is Fel=is qE(r) with E(r) equal to the electric force at distance r.
knowing this i believed the particle would not continue on its path but be pushed downwards in the vertical position. I used the right hand grip rule to figure it wouldn't just spiral in acircular clockwise path but in a helical anticlockwise path.
this the right idea?
sorry if I've written this in a confusing way lol
You need right hand grip rule for magnetic field i guess. This one is uniform electric field. So the path will be something like a parabola, cause direction of electric field is vertical, it will change only vertical component of velocity, horizontal component will stay same.
sorry i didnt mean the grip rule just the right hand rule. i checked it again and figured that if the particle was traveling along the +x axis and the electric field was in the -y direction...the force on the particle would be giong into the page(so to speak) this would make it travel in an anticlockwise direction. like you said the x direction wouldn't have changed so it would still be traveling with the same V so a helical path would be the right one...i hope :)
there will be no helical path, for this one you need certain combination of electric and magnetic fields. just google for helical path, you will see what it looks like. This problem is more like throwing balls - no helical - just a parabolic path.
the choices i have are
a) the particle stays on the same path,
b)the particle follows a circular path in an anticlockwise direction
c)the particle follows a circular path in a clockwise direction
d)the particle the particle follows a helical path in an anticlockwise direction
e)the particle follows a helical path in a clockwise direction
i can't see how it could be a because the electric field must have some sort of effect, even though the v is not stated.
i can't see b or c either because if it follows a circular path there must be a force pushing it back up against the electric field.
which is why i chose helical.
Im guessing this is wrong but can't see why.
Given a uniform electric field, all of those answers are wrong. The particle's path will be a parabola.
If we're discussing a uniform magnetic field, then the particle will follow a counter-clockwise helix upwards.
The right hand rule has absolutely nothing to do with the motion of a charged particle in an electric field.
what do i need to do to work that our RoyalCat? it is a magnetic field
Ah, be very careful with that. Magnetic fields and electrical fields affect moving charges very differently!
The Lorentz force on a charge moving with velocity [tex]\vec v[/tex] is given (In SI units) by:
[tex]\vec F = q(\vec E + \vec v \times \vec B)[/tex]
The magnetic force, as evident by its statement using the vector cross product, will always act perpendicular to the plane determined by the velocity and magnetic field vectors, with the direction being specified by the right hand rule.
Since the cross product derived force only acts on the the velocity component perpendicular to the magnetic field, the component of the velocity parallel to the magnetic field (This means either in exactly the same direction as the field, or exactly opposite it) remains unchanged. Superposing the two motions, one circular, and the other straight, makes for helical motion.
This page outlines the entire subject very well:
http://cnx.org/content/m31345/latest/
The electric field is uniform. E is not a function of r. E=constant. This is a projectile problem such as encountered for a mass in a uniform gravitational field without air resistance. Instead, you have charge and an electric field.
FAQ: Path of positivley charged particle in electric field
1. How does an electric field affect a positively charged particle?
An electric field exerts a force on a positively charged particle, causing it to accelerate in the direction of the field.
2. What determines the path of a positively charged particle in an electric field?
The path of a positively charged particle is determined by the strength and direction of the electric field, as well as the initial velocity of the particle.
3. Can a positively charged particle change direction in an electric field?
Yes, if the electric field is not uniform, the particle can change direction due to the changing force exerted on it.
4. How does the mass of a positively charged particle affect its path in an electric field?
The mass of a particle does not affect its path in an electric field. All particles with the same charge and initial velocity will follow the same path in the same electric field.
5. What is the difference between a positively charged particle's path in a uniform and non-uniform electric field?
In a uniform electric field, a positively charged particle will follow a straight line path. In a non-uniform electric field, the particle's path will curve due to the changing force exerted on it.
