Patterns found in complex numbers
In summary, complex numbers can be solved using De Moivre's theorem, with the equation z^n = r^n cis (nθ). When solving for z^n = i, the solutions are z=√3/2+0.5i, -√3/2+0.5i, and -i. However, the third solution was originally incorrect due to a missing variable, r. When generalizing this equation to z^n = 1+bi, where |a+bi|=1, the solution is -√3/2+i/2. If |a+bi| does
lll030lll
Patterns found in complex numbers URGENT!
  • use de moivre's theorem to obtain solutions to z^n = i for n=3, 4, 5
  • generalise and prove your results for z^n = 1+bi, where |a+bi|=1
  • what happens when |a+bi|≠1?
Relevant equations[/b]
r = √a^2 + b^2
z^n = r^n cis (nθ)
This is what i have done:
z^3=i
z^3=i cis(0)
z^3=cis(π/2+2kπ),k=0,1,2
z=cis(π/6+2kπ/3),k=0,1,2
z=cis(π/6),cis(π/6+2π/3),cis(π/6+4π/3)
z=√3/2+0.5i,-√3/2+0.5i,- √3/2-0.5i
but the 3rd solution is incorrect, should be -i. what have i done wrong?
welcome to pf!
hi lll030lll! welcome to pf! :smile:
dunno, but π/6+4π/3 = 9π/6 :redface:
(personally, i find degrees easier … 30°, 30° ± 120° :wink:)
anyway, got it right in using a+bi=re^iθ
Related to Patterns found in complex numbers
1. What are complex numbers?
Complex numbers are numbers that have both a real part and an imaginary part. They are written in the form a + bi, where a is the real part, b is the imaginary part, and i is the imaginary unit (equal to the square root of -1).
2. What is the significance of patterns found in complex numbers?
The patterns found in complex numbers can provide insights into the behavior and relationships between real and imaginary numbers. They can also be used to solve complex mathematical problems and equations.
3. How are complex numbers represented in the complex plane?
Complex numbers are represented in the complex plane as points, with the real part being the x-coordinate and the imaginary part being the y-coordinate. This allows for visualizing and understanding the relationships between complex numbers.
4. Can patterns in complex numbers be applied in real-world scenarios?
Yes, patterns found in complex numbers can be applied in various fields such as engineering, physics, and economics. For example, they can be used to analyze electrical circuits, model fluid dynamics, and predict stock market trends.
5. Are there any formulas or rules for finding patterns in complex numbers?
Yes, there are various formulas and rules for finding patterns in complex numbers, such as the Euler's formula, De Moivre's theorem, and the properties of complex conjugates. These can be used to simplify complex expressions and equations and identify patterns.
