Pauli exclusion principle and parallel spin.
In summary, the conversation discusses the concept of spin states in a two electron atom and how they relate to the quantum numbers n, l, and m(l). The book's statement about the spin states being parallel or antiparallel is misleading and incorrect. It is possible for the electrons to have different spin states while still having the same spatial wave function. This concept is also used in the description of orthohelium.
Silversonic
130
It's not a homework question. It's a piece of my textbook I don't understand.
Here's what it says
In a two electron atom, taking the orbital states of two electrons to be the same, then the antisymmetric wavefunction tends to zero, as well as the quantum numbers n, l and m(l) are the same for the electrons. Therefore, the possible spin wavefunctions are;
[itex]\chi[/itex][itex]_{a}[/itex], S = 0 (m[itex]_{s}[/itex] = 1/2 for one electron and m[itex]_{s}[/itex] = -1/2 for the other.[itex]\chi[/itex][itex]_{s}[/itex], S = 1 (electrons have the same (parallel) spin, i.e. both m[itex]_{s}[/itex] = 1/2 or -1/2), Since this combines with the antisymmetric orbital wavefunction which is zero, the total combined wavefunction of the orbital does not exist.
So we must have that an electron cannot exist with all the same four quantum numbers.
What I don't under is the bolded bit. It says that for S = 1 the electrons have the same spin. But surely this is untrue, it's possible to have m[itex]_{s}[/itex] = 1/2 for one electron and m[itex]_{s}[/itex] = -1/2 for another, but S = 1 still, as shown by this diagram;
http://img21.imageshack.us/img21/4033/12986325.png
i.e the M[itex]_{s}[/itex] = 0 in the middle (capitalised M) gives a state with S = 1 but m[itex]_{s}[/itex] = 1/2 for one and -1/2 for the other. Admittedly it doesn't matter since it combines with a 0 antisymmetric wavefunction, but still.
This same concept that I don't understand is used in the description of orthohelium. I'm not sure if orthohelium is defined as a helium atom where two electrons have the same spin, because as far as I see and anti-symmetric orbital wavefunction paired with a symmetric spin wavefunction (S=1) (which is orthohelium's wavefunction) can have electrons with different m[itex]_{s}[/itex].
Your textbook is misleading, if not wrong. I think what it meant to say is that:
  1. If the spins are parallel, the electrons are in a symmetric total spin state.
  2. If the electron spins are antiparallel, then it's possible the electrons are in the antisymmetric total spin state.
The converse of (1) isn't true, as you noted, and the book unfortunately makes it sound like antiparallel spins imply an antisymmetric state, which isn't correct either.
The consequence of (1) is that the spins of the electrons can't be parallel they have the same n, l, and ml quantum numbers. However, this doesn't necessarily mean that states with antiparallel spin exist. If all the antiparallel states were also symmetric, then you'd have to conclude there are no acceptable states where the two electrons have the same spatial quantum numbers.
Statement (2), however, says that an antisymmetric spin state does exist, so it is possible for an atom to have two electrons with the same spatial wave function. In that case, the spins must be antiparallel.
FAQ: Pauli exclusion principle and parallel spin.
What is the Pauli exclusion principle?
The Pauli exclusion principle states that no two identical fermions (particles with half-integer spin) can occupy the same quantum state simultaneously. This means that particles with the same spin cannot exist in the same place at the same time.
How does the Pauli exclusion principle affect electron configurations?
The Pauli exclusion principle plays a crucial role in determining the electron configurations of atoms. It states that each orbital can hold a maximum of two electrons with opposite spins. This explains the structure of the periodic table and the stability of atoms.
What are parallel spins?
Parallel spins refer to the alignment of two particles' spins in the same direction. In terms of the Pauli exclusion principle, this means that two particles with parallel spins cannot occupy the same quantum state.
What is the significance of parallel spins in the Pauli exclusion principle?
The Pauli exclusion principle is based on the concept of parallel spins. It states that particles with parallel spins cannot occupy the same quantum state, which is why electrons in an atom must have opposite spins in order to occupy the same orbital.
How does the Pauli exclusion principle contribute to the stability of matter?
The Pauli exclusion principle is one of the fundamental principles of quantum mechanics and plays a crucial role in determining the properties and stability of matter. It ensures that particles do not occupy the same quantum state, preventing them from collapsing into each other and thus contributing to the stability of matter.
