MHB Paul's questions at Yahoo Answers regarding tangent and normal lines
The discussion addresses several calculus problems related to tangent and normal lines, as well as critical points and points of inflection. The first question involves finding the equations of the tangent and normal lines to the curve y = x/a + a/x at the point (a/2, 5/2), with calculations yielding specific slopes and equations. The second question identifies the point on the parabola y = x^2 - 3x - 5 where the tangent is parallel to the line 3x - y = 2, resulting in the tangent line equation y = 3x - 14. The third question finds the normal line to the curve y = 3x^5 + 10x^3 + 15x + 1 at its point of inflection, with the normal line equation being y = -1/15x + 1. Lastly, the fourth question determines the critical points and points of inflection for the curve y = 3x^4 - 8x^3 + 6x^2, identifying (0,0) as a relative minimum and specific points of inflection.
MarkFL
MHB
Here are the questions:
Equation of tangent and normal?
1.find the equation of the tangent and normal to the curve y = x/a+a/x at (a/2, 5/2)
2. at what point of the parabola y=x^2-3x-5 is the tangent line parallel to 3x-y=2? find the eqn of the tangent line.
3. find the eqn. of the line normal to the curve y=3x^5+10x^3+15x+1 at its point of inflection.
4. find the critical points and the points of inflection of the curve y= 3x^4-8x^3+6x^2please show your solution. help me. thanks!
Here is a link to the questions:
Equation of tangent and normal? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello Paul,
1.) We are asked to find the equation of the tangent and normal lines to the curve $$y=\frac{x}{a}+\frac{a}{x}$$ at $$\left(\frac{a}{2},\frac{5}{2} \right)$$.
First, we need to compute the derivative of the curve to find the slopes:
$$\frac{dy}{dx}=\frac{1}{a}-\frac{a}{x^2}=\frac{x^2-a^2}{ax^2}$$
Hence, the slope of the tangent line is:
$$m=\left.\frac{dy}{dx} \right|_{x=\frac{a}{2}}=\frac{\left(\frac{a}{2} \right)^2-a^2}{a\left(\frac{a}{2} \right)^2}=-\frac{3}{a}$$
and so the slope of the normal line is:
$$-\frac{1}{m}=\frac{a}{3}$$
We now have the slopes and the point, so applying the point-slope formula, we find:
i) Tangent line:
$$y-\frac{5}{2}=-\frac{3}{a}\left(x-\frac{a}{2} \right)$$
$$y=-\frac{3}{a}x+4$$
ii) Normal line:
$$y-\frac{5}{2}=\frac{a}{3}\left(x-\frac{a}{2} \right)$$
$$y=\frac{a}{3}x+\frac{15-a^2}{6}$$
Here are some plots with a few values for $a$:
https://www.physicsforums.com/attachments/814._xfImport
2.) We are asked to find at what point of the parabola $y=x^2-3x-5$ is the tangent line parallel to $3x-y=2$? Find the equation of the tangent line.
First we observe that we may arrange the given line in slope-intercept form as follows:
$$y=3x-2$$
Now, we want to equate the derivative of the parabola to the slope of the line (since parallel lines have equal slopes):
$$2x-3=3$$
$$x=3$$
Now, to find the $y$-coordinate:
$$y(3)=(3)^2-3(3)-5=-5$$
and so we now have the slope $$m=3$$ and the point $$(3,-5)$$, and applying the point-slope formula, we find then that the equation of the tangent line parallel to the given line is:
$$y-(-5)=3(x-3)$$
$$y=3x-14$$
Here is a plot of the parabola, the given line, and the line tangent to the parabola and parallel to the given line:
https://www.physicsforums.com/attachments/815._xfImport
3.) We are asked to find the equation of the line normal to the curve $y=3x^5+10x^3+15x+1$ at its point of inflection.
From the first derivative, we may determine the slope of the tangent line, once we know where the point of inflection is.
$$\frac{dy}{dx}=15x^4+30x^2+15=15\left(x^2+1 \right)^2$$
$$\frac{d^2y}{dx^2}=60x^3+60x=60x\left(x^2+1 \right)=0$$
We find that the second derivative has only the real root $x=0$ and since it is of multiplicity 1, we know the second derivative changes sign across this root, hence the point of inflection is at $$(0,1)$$. Now the slope of the normal line is:
$$m=-\frac{1}{15}$$ and so, applying the point slope formula, we find the normal line is:
$$y-1=-\frac{1}{15}(x-0)$$
$$y=-\frac{1}{15}x+1$$
4.) We are asked to find the critical points and the points of inflection of the curve $y=3x^4-8x^3+6x^2$.
Critical or stationary points:
We want to equate the first derivative to zero, and solve for $x$:
$$\frac{dy}{dx}=12x^3-24x^2+12x=12x(x-1)^2=0$$
The critical values are then:
$$x=0,\,1$$
Because the root $x=1$ is of multiplcity 2, we may conclude that this is not an extremum, and by the first derivative test we know the critical value $x=0$ is at a relative minimum. Thus $$(0,0)$$ is a relative minimum.
Points of inflection:
$$\frac{d^2y}{dx^2}=36x^2-48x+12=12\left(3x^2-4x+1 \right)=12(3x-1)(x-1)=0$$
Since the roots are of multiplcity 1, we know the sign of the second derivative changes across then, and so we may conclude that the points of inflection are at:
$$\left(\frac{1}{3},\frac{11}{27} \right)$$
$$(1,1)$$
Here is a plot of the quartic function, showing its minimum at the origin and the points of inflection:
https://www.physicsforums.com/attachments/816._xfImport
To Paul and any other guests viewing this topic, I invite and encourage you to post other calculus problems here in our http://www.mathhelpboards.com/f10/ forum.
Best Regards,
Mark.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
