MHB PDF of X^2: General Method & Question Answered
  • Thread starter Thread starter nacho-man
    Pdf Writing
To find the PDF of Y = X^2 for a positive continuous random variable X, one must first determine the CDF of Y, which is expressed as P(Y < y) = P(X^2 < y) = P(X < √y). The PDF of Y can then be derived by differentiating this CDF with respect to y. The correct formula involves the PDF of X evaluated at √y, multiplied by the derivative of √y. This method clarifies the relationship between the PDFs of X and Y, addressing the initial confusion about their similarity.
nacho-man
I just started this topic and have a question:
For a positive continuous random variable X, write down the PDF of Y = X^2 in terms of the PDF of X.
So; writing the PDF of X, I get
P(0<X<∞) =integral from 0 to ∞ fx(x)dx
Is this correct? For Y=X^2, wouldn't the pdf be the exact same thing, since the question asks for positive continuous random variables anyway?
Is there a general method, approach I should have about this. I find pdfs to be confusing, the textbooks are heavy on jargon.
Welcome to MHB, nacho! :)
Since your questions were sufficiently different to warrant their own threads, I have taken the liberty to split them into 2 threads. We prefer 1 question per thread here (unless the questions are parts of the same problem statement).
Now to address your problem, to find a PDF, the general method is to look at the CDF and take its derivative.
In your case the CDF of Y is:
$$P(Y < y) = P(X^2 < y) = P(X < \sqrt y) = \int_{0}^{\sqrt y} f_X(x) dx$$
Note that the lower boundary can be zero, since X is given to be positive.
To find the PDF of Y, you need to differentiate its CDF.
$$f_Y(y) = \frac{d}{dy}P(Y < y)$$
Now supposed $F_X(x)$ is the anti-derivative of $f_X(x)$, which is actually the same as the CDF of X, then you get:
$$f_Y(y) = \frac{d}{dy}P(Y < y) = \frac{d}{dy}\int_{0}^{\sqrt y} f_X(x) dx
=\frac{d}{dy}\Big(F_X(\sqrt y) - 0\Big) = f_X(\sqrt y) \frac{d}{dy}(\sqrt y)$$
Does that answer your question?
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
