MHB -pe.7 write a system in the matrix form Y'=AY+G
karush
MHB
nmh{896} mnt{347.21}
consider th non-homogeneous first order differential system
where $x,y,z$ are all functions of the variable t
\begin{align*}\displaystyle
x'&=-4x-3y+3z\\
y'&=3x+2y-3z+e^t\\
z´&=-3x-3y+2z
\end{align*}
write a system in the matrix form $Y'=AY+G$
karush said:
consider the non-homogeneous first order differential system
x'&=-4x-3y+3z\\
y'&=3x+2y-3z+e^t\\
z´&=-3x-3y+2z
\end{align*}
Start by taking $Y = \begin{bmatrix}x\\y\\z\end{bmatrix}$. Then the equation $Y'=AY+G$ becomes $$\def\dot{\phantom{\bullet}} \begin{bmatrix}x'\\y'\\z'\end{bmatrix} = \begin{bmatrix}\dot&\dot&\dot\\ \dot&\dot&\dot \\ \dot&\dot&\dot\end{bmatrix} \begin{bmatrix}x\\y\\z\end{bmatrix} + \begin{bmatrix}\dot\\ \dot\\ \dot\end{bmatrix}.$$ Can you fill in the blanks?
$$Y'=\left[\begin{array}{rrrr}-4&-3&3\\3&2&-3&+e^t\\ -3&-3&2\end{array}\right]
+ \begin{bmatrix}G_1\\ G_2\\G_3\end{bmatrix}$$ok I don't know if this is all they want but presume what we do next is a rref on A
also this has an $e^t$ in it.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
