Pebble dropped on rotating wheel, starts to slide after rotation
In summary, a pebble is placed on top of a wheel with a radius of 50cm and a velocity of 2m/s. The coefficient of friction between the wheel and pebble is 1, and the pebble starts to slide down when it has rotated through an angle θ with the vertical axis. To calculate θ, a force diagram should be drawn and relevant equations should be used. The pebble is assumed to be at rest relative to the point on the wheel where it is placed, and when the wheel has moved through an angle θ, it is rotating about a certain point and moving at a certain speed. The force required to keep it rotating about that point and the forces acting on the pebble in
zibs.shirsh
A wheel of radius R=50cm rolls along the ground with velocity V=2m/s. A pebble released on top of the wheel so that it is instantaneously at rest on the wheel. The co-efficient of friction between wheel and pebble is μ=1. The pebble starts to slide down when it has rotated through angle θ with the vertical axis.
Calculate θ.
Absolutely No idea
Couldn't attempt
Try drawing a force diagram. This always helps. I am sure you can think of some relevant equations.
I assume it means at rest relative to the point on the wheel where it is placed.
When the wheel has moved through an angle theta (with the pebble not having slipped yet):
- what point is the pebble rotating about?
- how fast is it moving?
- what force is required to keep it rotating about that point?
- what forces act on the pebble, and in what directions?
it as no equations were provided.
I would first gather more information about the problem and the variables involved. From the given information, we know that the wheel has a radius of 50cm and is moving with a velocity of 2m/s. The pebble is released on top of the wheel and has a coefficient of friction of 1 with the wheel. We are asked to calculate the angle θ at which the pebble starts to slide down the wheel.
To solve this problem, we need to use the equations of rotational motion and the concept of centripetal force. The equations of rotational motion are:
ω = ω0 + αt (1)
θ = ω0t + 1/2αt^2 (2)
ω^2 = ω0^2 + 2αθ (3)
where ω is the final angular velocity, ω0 is the initial angular velocity, α is the angular acceleration, t is time, and θ is the angle rotated.
We also know that the centripetal force, Fc, is given by:
Fc = mv^2/r (4)
where m is the mass of the pebble, v is the velocity of the wheel, and r is the radius of the wheel.
To solve for θ, we can use equations (1) and (4). We know that at the point where the pebble starts to slide, the centripetal force is equal to the frictional force, which is given by:
Ff = μN (5)
where μ is the coefficient of friction and N is the normal force.
Substituting equations (4) and (5) into (1), we get:
μmg = mv^2/r (6)
Solving for θ in equation (2), we get:
θ = ω0t + 1/2αt^2 (7)
Substituting equations (6) and (7) into (3), we get:
ω^2 = ω0^2 + 2αθ (8)
Solving for ω, we get:
ω = √(ω0^2 + 2αθ) (9)
Substituting equation (9) into (6), we get:
μmg = m(ω0^2 + 2αθ)r (10)
Solving for θ, we get:
θ = (
Related to Pebble dropped on rotating wheel, starts to slide after rotation
1. What causes the pebble to start sliding after rotation?
The pebble starts sliding after rotation due to the centrifugal force acting on it. As the wheel rotates, the pebble experiences an outward force that causes it to slide.
2. Does the size of the pebble affect when it starts sliding?
Yes, the size of the pebble does affect when it starts sliding. A larger pebble will have a greater mass and therefore require a greater centrifugal force to overcome the force of friction and start sliding.
3. Why does the pebble not slide off immediately when the wheel starts rotating?
The pebble does not slide off immediately because of the force of friction between the pebble and the surface of the wheel. This force must be overcome by the centrifugal force before the pebble can start sliding.
4. How does the speed of rotation affect when the pebble starts sliding?
The speed of rotation affects when the pebble starts sliding because it directly affects the amount of centrifugal force acting on the pebble. The faster the wheel rotates, the greater the centrifugal force and the earlier the pebble will start sliding.
5. Can the angle of the wheel's rotation affect when the pebble starts sliding?
Yes, the angle of the wheel's rotation can affect when the pebble starts sliding. A steeper angle of rotation will result in a greater centrifugal force, causing the pebble to start sliding earlier than if the wheel was rotating at a shallower angle.
