Pendulum Clock -- Change in frequency with change in temperature
In summary, the conversation discusses the concept of a pendulum clock remaining accurate to 1 second in 24 hours. The reasoning behind this is based on the equation for the period of a physical pendulum and the assumption that the pendulum swings in a vacuum without the effect of friction. The equation used is P = 2π √(L/g) and the solution involves finding the value for α to determine δT. The conversation also mentions the use of an ideal pendulum with small amplitude swings and no friction.
Sarah0001
31
For this problem you can consider an ideal pendulum,
for which you will calculate the effect of changing its environment.
(d) Most substances expand with increasing temperature, and so a
metal rod will expand in length by a fraction α δT if the temperature is changed by δT, where α is called the coefficient of linear thermal expansion. Consider the effect of this expansion on a pendulum clock with a pendulum made from brass, with α = 19 × 10^-6 K^-1 .
What temperature change can this clock tolerate if it is to remain accurate to 1 second in 24 hours?
P=2π √(L/g)
1) I do not quite understand how the phrase remain accurate to 1 second in 24 hours? , means ΔP = 1 second,
2) I also don't understand how pendulum period P should be 24 hours
What is the reasoning for both?
The solution is as such
P = 2π √(L/g) P' = 2π √((L+L α δT)/g)
ΔP = P'- P = 2π √((L(1+ α δT)/g) - 2π √(L/g)
where 2π √(L/g) factored out from above to give :
ΔP = 2π √(L/g) ( (√(1+ α δT) - 1)
ΔP = P ( (√(1+ α δT) - 1)
ΔP = 1 sec (which I don't understand this part)
also P = 24 hours = 24*3600 secs ( which I don't understand how one pendulum period should be 24 hours?, I don't understand the reasoning behind this.)
ΔP/P = 1/24*3600
ΔP/P = P ( (√(1+ α δT) - 1) /P
√(1+ α δT) - 1 =1/24*3600
then the value for α can be plugged in and rearranged to find δT.
Does it really say ΔP = 1 sec and P = 24 hours, or are you inferring that from:
Sarah0001 said:
ΔP/P = 1/24*3600
1 second in 24 hours is the fractional change in the clock rate, so is also the fractional change in the period.
Ah yes sorry, I was inferring ΔP = 1 sec and P = 24 hours from the solutions, I just don't understand how they reasoned this in the first place upon reading the question.
(I think this is because do not completely understand part of the question (if the pendulum clock to remain accurate to 1 second in 24 hours?' ) is asking. )
Suppose it should execute N periods in 24 hours. I.e. NP= 24 hours.
If the period has changed to P+ΔP then after N periods the elapsed time is N(P+ΔP). So NΔP= 1 second.
So ΔP/P=(NΔP)/(NP)=1 sec/ 24 hours.
Likes Sarah0001
Hi.
I'm thinking the homework problem requires the equation for the period of a physical pendulum (Hint: moment of inertia of a rod about an axis through its end is I= 1/3ML^2). So don't use the equation for the period of the simple pendulum, as you stated in your work.
Perhaps by "ideal" the pendulum swings in a vacuum without the effect of friction, and has small amplitude swings, but is still a rod pendulum.
I hope that helps.
No, it changes nothing.
E.g. if the pendulum consists of a point mass M on the end of a uniform rod mass m, length L, the moment of inertia is still proportional to L2, and the torque at a given angle is still proportional to L.
Related to Pendulum Clock -- Change in frequency with change in temperature
1. How does temperature affect the frequency of a pendulum clock?
The frequency of a pendulum clock is dependent on the length of the pendulum and the force of gravity. However, temperature can also impact the frequency by changing the length of the pendulum. As temperature increases, the pendulum expands and its length increases, causing the frequency to decrease. Conversely, as temperature decreases, the pendulum contracts and its length decreases, causing the frequency to increase.
2. What is the mathematical formula for calculating the change in frequency of a pendulum clock with a change in temperature?
The mathematical formula for calculating the change in frequency of a pendulum clock with a change in temperature is: Δf = (α * L * ΔT) / T, where Δf is the change in frequency, α is the coefficient of thermal expansion, L is the length of the pendulum, ΔT is the change in temperature, and T is the original temperature.
3. How significant is the change in frequency for a pendulum clock with a change in temperature?
The change in frequency for a pendulum clock with a change in temperature can vary depending on the material of the pendulum and the magnitude of the temperature change. For example, a brass pendulum may have a change in frequency of 0.02 seconds per day for every 1 degree Celsius change in temperature. While this may seem small, over time it can accumulate and affect the accuracy of the clock.
4. Can the change in frequency due to temperature be compensated for in a pendulum clock?
Yes, the change in frequency due to temperature can be compensated for in a pendulum clock. This can be done by adjusting the length of the pendulum or by using a pendulum made of a material with a lower coefficient of thermal expansion, such as steel. Another method is to use a temperature-compensated pendulum, which has a built-in device that automatically adjusts the length of the pendulum as the temperature changes.
5. How does the change in frequency with temperature affect the accuracy of pendulum clocks?
The change in frequency with temperature can affect the accuracy of pendulum clocks, especially over long periods of time. If the temperature fluctuates frequently, the clock may gain or lose time. However, by compensating for the change in frequency, the accuracy can be improved. In modern pendulum clocks, this compensation is often built-in, but older clocks may require manual adjustments to maintain accuracy.
9K
