Dreshawn
- 1
I am struggling with setting up a problem to solve for the change in amplitude of a pendulum affected by a damping force (presumable air friction) over a time period.
The original amplitude of the pendulum is 1.4 m from the equilibrium on a 15 m massless wire with a 110 kg brass bob at the end. The damping force is 0.010 kg/s. This force is dependent on velocity and I have set up an equation for velocity dependent on time -
dv/dt = -ωAsin(ωt+Φ0). I know that this force will always oppose motion but I am having trouble putting these together to see the affect on the pendulum bob's acceleration and amplitude. I was wondering if I should just use the pendulums max velocity at the bottom to approximate this damping force & then apply this to the # of oscillations to get a rough estimate on the decrease of acceleration at the bottom & then solve for amplitude or if there is another more accurate way to solve this problem.
Thank you
Thank you
