Pendulum - How it affects gear train torque?
In summary, the question is whether lengthening the pendulum in a classic weight-driven clock will see a change in torque on the gear train. The answer is that the torque applied by the gear train/escapement on the pendulum is unchanged by the length of the pendulum. This is because the pendulum is a driven oscillator and does not apply torque to the gear train. Additionally, the torque applied by the pendulum to the escapement/gear train is also unchanged according to Newton's third law. The placement of the escapement/pendulum assembly between gears may affect the torque on downstream gears, but it is unclear without further information.
jryer
Does the gear train in a classic weight driven clock see a torque decrease when we lengthen the pendulum?
thanks guys for your help - (inventor question)
Are you asking this as a physics question or as a design question?
The physics version would be: "How would lengthening the part of the pendulum below the pivot point change the torque delivered by the escapement"
The design question would be: "How would lengthening the part of the pendulum below the pivot point change the torque required from the escapement".
The first one - "How would lengthening the part of the pendulum below the pivot point change the torque delivered by the escapement; would it increase or decrease?"
Also, I'm assuming the change in the torque delivered is transferred (seen/realized) to the gear train, is this a correct assumption?
Possibly we are still speaking at cross-purposes.
To my way of thinking, the pendulum is a driven oscillator. It does not apply torque to the gear train. The gear train applies torque to it. In the absence of any applied torque, it would continue move back and forth in an arc that slowly decreases over time due primarily to air resistance.
The gear train has to provide enough torque to overcome the losses due to air resistance. But it must not provide so much so that the pendulum's arc increases too greatly. [The escapement assures that this torque is applied in proper synchronization with the pendulum's motion].
So my answer is that the torque applied by the gear train/escapement on the pendulum is unchanged by the length of the pendulum. From Newton's third law, the torque applied by the pendulum to the escapement/gear train is also unchanged.
JBriggs, take a look at this link
http://electronics.howstuffworks.com/gadgets/clocks-watches/clock4.htm
What happens if we put the escapement/pendulum assembly between the blue (1st) and purple (2nd) gears? Now does lengthening the pendulum affect the torque on the downstream gears (purple, green, and plum gears)?
thanks again
Bump. Anyone care to contribute on the 7:50pm post? thanks again
FAQ: Pendulum - How it affects gear train torque?
What is a pendulum and how does it affect gear train torque?
A pendulum is a weight suspended from a fixed point that swings back and forth under the force of gravity. In a gear train, the pendulum's movement can create a change in torque due to its oscillation and the laws of physics.
How does the length of the pendulum affect gear train torque?
The length of the pendulum can affect the gear train torque by changing the period of its swing. A longer pendulum will have a longer period, which means it will take more time to complete one full swing. This longer period results in a decrease in the frequency of oscillation, leading to a decrease in torque.
Can the weight of the pendulum impact gear train torque?
Yes, the weight of the pendulum can affect gear train torque. A heavier pendulum will have more inertia, which means it will require more force to change its direction of motion. This increased inertia can lead to a decrease in torque due to the pendulum's resistance to changes in direction.
How does the angle of the pendulum's swing affect gear train torque?
The angle of the pendulum's swing can impact gear train torque in two ways. Firstly, a larger swing angle will result in a longer distance traveled by the pendulum, leading to a longer period and a decrease in torque. Secondly, the angle of the pendulum's swing can also affect the direction and magnitude of the force applied to the gear train, resulting in changes in torque.
What other factors can influence the impact of a pendulum on gear train torque?
Other factors that can influence the impact of a pendulum on gear train torque include the material and shape of the pendulum, air resistance, and friction. The material and shape of the pendulum can affect its inertia and the force it applies to the gear train. Air resistance and friction can also impact the pendulum's movement and the torque it exerts on the gear train.
