Pendulum in an accelerating car
In summary: Not it isn't. First of all that isn't even dimensionally consistent. Secondly, the acceleration of the car gives rise to an inertial force in the rest frame of the car but not only is this is a use of non-inertial frames (which the OP said was not a desired method) but also it involves...
andyrk
658
When a car is accelerating with a pendulum hanging inside it, then why does the pendulum get aligned with the vertical at an angle? Can you explain it without using the concept of pseudo force? I tried it but I was not able to get it.
My Attempt:
According to what has been taught in the class, for determining which way the pendulum gets aligned, we assume anyone direction and then resolve the tension force in the string in 2 directions. One along the motion of the car and the other upward, towards the roof of the car.
Using the horizontal direction force we can judge which way the pendulum should actually align using Newton's Second Law of Motion F is proportional to a (acceleration). But following this the pendulum should align in the forward direction, i.e the right direction if the car is accelerating towards right. But its the opposite, i.e the pendulum aligns leftwards and not rightwards. Can anyone explain why this happens?
Hi andyrk...
Consider a small ball of mass 'm' hanging by a light string in the car .
Suppose the car moves horizontally towards right with acceleration 'a' . What should be the horizontal acceleration of the bob after it has come at rest with respect to the car ?
You are correct that the equilibrium position of the pendulum is found by resolving the forces. I think the reason why the bob lags behind is because its inertia is trying to keep it in the same place, and what we see is the (equal and opposite) reaction to the forward force.
Tanya Sharma said:
Hi andyrk...
But that is again involving a Non Inertial frame of reference. Can't this be explained via inertial frame of reference, i.e the ground?
No...I am explaining this using inertial frame only .
The ball accelerates horizontally with acceleration 'a' . The only way it can do so is if there is a component of force in the horizontal direction .This is possible only when the ball makes an angle θ with the vertical such that Tsinθ provides the necessary horizontal force .The ball has to be towards left side of the vertical line .
This is not possible if the ball is towards right or if it stays making zero angle with the vertical .
Hmm..Yes you are right. Thanks.
Consider two accelerations being applied via forcers: Gravity, and the acceleration of the car. The sum of the forces (which act in different directions) will give you and effective acceleration, say g'. This is NOT directly downwards, which explains why the pendulum is in equilibrium at an angle to the vertical
The acceleration of the car is not a force - it is a result of forces. Your argument amounts to use of pseudo-forces, which was ruled out in the OP.
The acceleration of the car is a force, inertially, because the pendulum is mounted at a hinge which is accelerating at [itex]a_\text{car}[/itex]
Not it isn't. First of all that isn't even dimensionally consistent. Secondly, the acceleration of the car gives rise to an inertial force in the rest frame of the car but not only is this is a use of non-inertial frames (which the OP said was not a desired method) but also it involves the use of a force that vanishes in the lab frame that the OP wants to work in.
Related to Pendulum in an accelerating car
1. How does the acceleration of a car affect the motion of a pendulum inside?
As the car accelerates, the pendulum will appear to swing backwards, towards the direction of acceleration. This is due to the inertia of the pendulum, which causes it to resist changes in its state of motion.
2. Can the pendulum inside an accelerating car ever reach a state of equilibrium?
No, the pendulum will continue to oscillate back and forth as the car accelerates. The only way for it to reach a state of equilibrium is if the car maintains a constant velocity.
3. How does the length of the pendulum affect its motion in an accelerating car?
The length of the pendulum will affect the period of its oscillation, but it will not change the fact that it will appear to swing backwards towards the direction of acceleration. A longer pendulum will have a longer period of oscillation compared to a shorter pendulum.
4. Does the pendulum behave differently if the car is accelerating in a circular motion?
Yes, the pendulum will still appear to swing backwards, but it will also experience a centrifugal force due to the circular motion. This force will cause the pendulum to appear to swing outwards, away from the center of the car.
5. Why does the pendulum behave differently in an accelerating car compared to a stationary car?
In a stationary car, the pendulum will swing back and forth in a straight line due to the force of gravity. However, in an accelerating car, the acceleration will cause the pendulum to experience a pseudo-force that appears to pull it backwards, causing it to swing in a curved path.
