Pendulum Problem and steiner' law
  • Thread starter Thread starter ChazyChazLive
    Law Pendulum
The discussion focuses on calculating the period of a uniform circular disk acting as a physical pendulum and finding an alternative pivot point that yields the same period. The period is calculated using the formula T = 2π√(I/mgh), with the correct answer for part A being 0.849 seconds. For part B, participants suggest using Steiner's law to express the moment of inertia (I) through a parallel axis. The goal is to equate the period of the disk to that of a simple pendulum to determine the radial distance r. The conversation emphasizes the application of physics principles to solve the problem effectively.
ChazyChazLive
A uniform circular disk whose radius R is 14.3 cm is suspended as a physical pendulum from a point on its rim. (a) What is its period? (b) At what radial distance r < R is there a pivot point that gives the same period? (give answer in cm)
T= 2pi radical ( I / mgh )
Okay, I already found part A using T= 2pi radical ( I / mgh )
Any help would be greatly appreciated =]
Part A: 0.849 s <-- It's correct.
I'm just stuck on Part B.
Use steiner' law to express the I through a parallel axis..
You can find the radial distance by equating period of the disk to that of a simple pendulum.
