Pendulum swinging above earth's surface
In summary: You already knew that. :)had you expressed your answer to 3 figures you would be giving the same answer as me.Thank you for your help. I have a habit of not rounding, I'm glad my professor isn't too harsh about it.
rubenhero
42
Assume all oscillators are frictionless.
a) A pendulum consists of point mass Mo swinging on a massless string of length Lo, with period To = 9.42 s on the surface of the Earth (at RE, the radius of the Earth). Find T1, the period of the same pendulum if it swings on a horizontal platform of height H = 2.96RE (stationary, not orbiting) above the Earth's surface.
T = 2∏√(L/g) , g = GM/R2 , Radius of Earth = 6.37e6m, mass of Earth = 5.98e24kg
g(T/2∏)2 = L
9.81m/s2√(9.42s/2∏)2 = 22.05012604m
g = GM/R2
(6.67e-11 * 5.98e24kg)/(2.96 * 6.37e6)2 = g1
3.98866e14/3.55518567e14 = 1.121927339m/s2 = g1
T1 = 2∏√(L/g1)
T1 = 2∏√(22.05012604/1.121927339)
T1 = 27.85499219s
The answer i calculated is wrong, any help with figuring out why it's wrong would be greatly appreciated:smile:
g(T/2∏)2 = L
g = GM/R2
T1 = 2∏√(L/g1)
T1 = 27.85499219s
The R in the formula g = GM/R2 is the distance from the centre of the Earth.
This pendulum is set up 2.96RE above the surface, so 3.96RE from the centre.
Thank you for the response Peter. Are you saying that the R in the equation should be RE + 2.96RE?
I think yes. After you have worked it out, I will show you how I would have done the question - in a very simply way.
Ok so I redid the problem with the correction of the R. g = (6.67e-11 * 5.98e24kg)/((2.96*6.37e6)+6.37e6)2 and got a g = .626841558. Then T = 2∏√(22.05012604/.626841558) and got T = 37.26s. I think that period should be right, I'm interested in your alternate method to solving this type of problem:smile:
OK it amounts to using variation.
You already knew
T = 2∏√L/g and g = GM/R2
Substitute the expression for g into the first expression and we get
T = 2∏√(LR2/GM)
most of those terms don't change, so replacing 2∏√(L/GM) with something simple like k we get
T = kR
Now the new R value is 3.96 times the R value at the surface, so simple arithmetic →
T = 9.42 x 3.96 → 37.3072s or 37.3 s when respecting the significant figures in supplied data.
A couple of things to note:
1: This type of comparative approach is very powerful and leads to simple calculation.
2: Giving the distance above the Earth Surface is a common "tester" used in problems.
It is always fun to see people calculate that gravity 600km above the surface is way stronger than at the surface, because someone calculates with R = 600 000 m rather than 600 000 m MORE than the Radius of the Earth.
Another example:
Compare the centripetal acceleration of a satellite orbiting a distance RE above the surface of the earth, to one orbiting at a distance 2RE above the surface.
The centripetal acceleration is simple g at the point.
Knowing the formula g = GM/R2 leads some to assume an answer 4:1, but of course it is actually 9:4 since the R values to use in the formula are not RE & 2RE but 2RE & 3RE
Note: I think your answer of 37.26 varies from my 37.3026 due to the rounded off values of Earth mass and Radius you have used.
Thank you for your help. I have a habit of not rounding, I'm glad my professor isn't too harsh about it. I found that your alternate way of doing this calculation to be much more efficient. I think the extra example you mentioned is cleverly worded and is very possible for my professor to put something similar on the next exam. I appreciate your time and patience spent helping me.
Related to Pendulum swinging above earth's surface
1. How does the length of the pendulum affect its swing?
The length of the pendulum affects its swing because it determines the period, or the time it takes for one complete back-and-forth motion. A longer pendulum will have a longer period, while a shorter pendulum will have a shorter period. This is because the longer pendulum has a longer distance to cover in the same amount of time, therefore taking longer to complete one swing.
2. Does the mass of the pendulum affect its swing?
The mass of the pendulum does not affect its swing as long as the mass is concentrated at the end of the pendulum (the bob). This is because the swinging motion is caused by the force of gravity acting on the bob, not the mass itself. However, if the mass is distributed along the length of the pendulum, it can affect the swing by changing the center of mass.
3. How does gravity affect the swing of a pendulum?
Gravity is the force that pulls the pendulum towards the center of the earth, causing it to swing back and forth. The strength of gravity does not affect the swing of the pendulum, but the length of the pendulum and the angle at which it is released can affect the force of gravity acting on the pendulum.
4. What is the relationship between the amplitude and the energy of a pendulum?
The amplitude, or the maximum distance the pendulum swings from its resting point, is directly proportional to the energy of the pendulum. This means that the higher the amplitude, the more energy the pendulum has. This is because the pendulum gains potential energy as it swings higher and then converts it into kinetic energy as it swings back down.
5. Can a pendulum ever reach a point of equilibrium and stop swinging?
In a perfect environment with no external forces acting on the pendulum, it will eventually reach a point of equilibrium and stop swinging. However, in the real world, there are always external forces such as air resistance and friction that will cause the pendulum to eventually come to a stop. Additionally, the swinging motion will gradually decrease in amplitude due to the loss of energy through these external forces.
13K
