Perceived Color of objects: in White light from a TV
In summary, a yellow banana will look yellow when illuminated by white light because the yellow wavelength stimulates both Red and Green cells in the eye.
Anand Sivaram
90
43
Background: Normal white Sun light has a continuous spectrum in the whole of visible range. But, white light (rather what we perceive as white) coming out of a Monitor/TV is have only RGB in it and
it looks white because of the Tricolor vision which excites all three types of cells in the eye.
If we take a yellow object (say banana) to Sun light, it will look yellow because it reflects yellow light (wavelength) and this yellow wavelength light excites both Red and Green cells in the eye.
Now, if we take the same Banana in front of a Monitor/TV which is displaying a white object, how should we perceive the color of the Banana?
I was thinking that we should not be able to perceive the color because:
The Monitor/TV puts out three different wavelengths (RGB) only, since the banana could reflect only yellow wavelength, it could not reflect the Red, Green or Blue wavelengths coming out of the Monitor/TV, that way it should be seen as dark.
But, when I tried it, I could really see it as yellow. Could anyone explain this please?
Science news on Phys.org
Perhaps the banana is more complicated than you first assumed.
Your assumption is that the banana absorbs all wavelengths except for yellow. Reconsider this assumption based on new evidence.
I found this interesting reference which might help.
Note that as the banana ripens, the reflectance in the yellow, orange, and red spectra all significantly increase. The main takeaway here is that the reflectance at no point is simply a single peak in the yellow band.
http://ucanr.edu/datastoreFiles/234-953.pdf
Surprise: CONES in your eye actually record red, yellow, blues in combination and the brain combines them as 'yellow'. The object itself is not 'yellow'.
About 64 percent of cones respond most strongly to red light, while about a third are set off the most by green light. Another 2 percent respond strongest to blue light. Rods detect brightness.
When reflected light of different wavelengths from a banana hits the cones, it stimulates them to varying degrees. The resulting signal is passed along to the brain, which determines a color: yellow.
Many birds and fish may have four types of cones, enabling them to see ultraviolet light, or light with wavelengths shorter than what the human eye can perceive.
PS: good question!
Likes RUber
There are many situations in physics where our senses 'cannot be trusted'. That is, our evolution may not have equipped us to 'intuitively' see things as we imagine. A common example is Einstein passing everyday intuition and realizing that space and time are not fixed and immutable, but rather vary by observer. He correctly concluded only the speed of light in a vacuum is the real 'constant'.
I can think of a few examples where you and I do not see the 'same color' yellow banana. One obvious situation is where we have inherited different numbers or proportions of color sensing cones. And having us look at a color chart would not enable us to 'pick a difference'. Also, people with color blindness, and I am not sure exactly what that is, may not be able discern,say, red from green. My cousin who is somewhat color blind sometimes see grays where I see 'colors'.
Also, if you rapidly approach [or depart from ] a banana, approaching a significant percentage of light speed, you'll see a significantly different color than when you are stationary with respect to the banana. The speed of light is fixed, but you'd detect different wavelengths [colors]. Same situation if you were sitting here on Earth and watched a banana on a rapidly moving spaceship. As the spaceship picks up speed, the color of the banana changes.
But, when I tried it, I could really see it as yellow. Could anyone explain this please?[/QUOTE]
The colours from the three phosphors are not a single wavelength but cover wide overlapping bands, so the banana does receive illumination.
Likes Merlin3189
All true - the RGB monitor light sources are not monochromatic, neither is the banana spectral reflectance, nor is your retinal sensitivity. Also, the brain compensates for color casts to give you an 'expected color' anyway. If you look at a white shirt after wearing pink sunglasses for a while, you see it as white, although it might appear pink when you first put the glasses on.
This is not true. Read the posts above, look ate the graph in post #3.
Or read the paper
http://ucce.ucdavis.edu/files/datastore/234-953.pdf
you are missing the point on how colour is created by the TV
various RGB levels are not "transmitted" in different amounts from the screen and you eye/brain perceives a specific colour from that
rather the specific colour is generated at/on the TV screen by the mixing of the appropriate 3 colours RGB and that colour is "transmitted" to your eye
meaning ... a white area on the screen is just that, white, whether you are looking at it or not and that would be confirmed
by using some other electronic colour sensor rather than your eye
Dave
There is a great temptation to confuse colour and wavelength. This should be avoided, as it will lead your understanding of colour vision right down the garden path.
I have just looked at my Apple iMac monitor with my recently obtained, cheap and cheerful. diffraction grating spectroscope. Far from consisting of "three wavelengths". the light from a white screen consists of three very broad bands of 'Reds', 'Greens" and 'Blues' and not three single wavelengths at all. This is not at all surprising because it is hard to produce enough light from a monochromatic source. There is a definite gap between the bands and there are no wavelengths that could be described as yellow or cyan. Using appropriate amounts of each (broadband) phosphor, you can produce a simulation that's acceptable to most normally sighted people of any of the visible colours (with the exceptions of monochromatic sources ( consisting only of one spectral line).
The answer to the banana question lies in the Analysis of the eye and its model that is used in a TV camera - not with the display technology.
This link shows the responses of the three sets of colour receptors. Each sensor, although commonly thought of being selectively sensitive to reds, greens and blues, is actually sensitive to almost all visible wavelengths. A 'coloured' image or object will stimulate all three sensors to different degrees (tristimulus values) and it is the ratio of the respective amounts that gives the impression of 'colour'. An infinite number of combinations of incident wavelengths can produce the same perceived colour. The spectrum of light from a banana, as shown above, is very broadband and definitely not 'spectral' (monochromatic) yellow. You can obtain a very good match to this 'yellow' by mixing the outputs from the three RGB phosphors. Human colour vision has no way of doing better than this. It is not a spectrometer and has no need to be. It gets by quite well enough with just three analyses. If more was necessary then evolution would probably have given us more - thousands even, as with our sound detecting hardware (the cochlea) which has a 'proper' audio spectrum analyser built in.
Likes RUber
Thanks a lot everyone for the answers.. Found a lot of valuable information :)
Unlike what I thought the 3 pixel phosphors emit a band spectrum.
BTW I searched for spectrum of computer monitor and found the following links.. People have analyzed the spectrum using spectroscopes..
http://www.chemistryland.com/CHM107Lab/Exp7/Spectroscope/Spectroscope.html
http://home.freeuk.com/m.gavin/grism2.htm
Anyone has an idea what type of Color Rendition Index (CRI) corresponding to the white light emitted by a Monitor/TV ?
It is not normal to use a TV monitor to illuminate objects and the CRI of a light source tells you how that light source will behave as an illuminant. I have not seen colour monitors assigned a CRI. A colour monitor has a 'white point', which is the point on the colour space of a picture that is taken to be where a perfectly white matt reflecting surface will sit on the CIE colour chart. It is a common operation to change the white point of a picture from where the original illuminant would sit. You can warm up a 'cold' scene by altering the colour balance and you can sometimes reduce the ghastly effects of colour cast that some fluorescent lamps can inflict on an otherwise pretty scene.
There is a distinction between analysis and synthesis of colours and the two processes have to be treated differently. The finer points are beyond me and you are welcome to get stuck into the details of colourimetry. But watch out for the high levels of BS that non technical but often very artistically talented people use when describing how they deal with colour. A lot of the published material is about printing and paints, which is a very dark art, in my experience.
Playing is fun, isn't it? :)
Likes sophiecentaur
The thing only cost me about $30 (including postage from the US). I have learned that LED lamps have pretty continuous spectra, which explains how they work much better than the CFLs with a similar perceived 'colour'. The CFL spectrum is like a dog's dinner with lines, odd bands and gaps all over the place. No wonder they play hell with colour matching.
Every home should have one (spectroscope, I mean). Plus it doesn't need a danged battery!
Likes davenn
and for that alone they should be banned
I think Natural Selection will cause their demise pretty soon. LEDs are getting so cheap and CFLs have pretty short lives, mostly. (Despite what we were told)
yeah, I have discovered a poor life span out of many of them
plus they have the same toxic chemicals in them as full size fluoro's do :rolleyes::rolleyes:
a total con perpetrated on society (another to add to the growing list haha)
Likes sophiecentaur
My spectroscope came in yesterday. I did the same. :smile:
I'm now developing plans on how best to illuminate a banana to get a clear spectrum, to verify that bananas are not in fact yellow, but just red & green spotted monsters. :biggrin: (See post #3)
Then, I'll take an image of the banana in sunlight, as that is the "CRI" reference. (kind of, I think)
Then, I'll transfer the image to my PC, and take an image of that image, and compare them spectrally, via RGB values.
And then we will have the "CRI", within at least 2 orders magnitude accuracy, as that is usually how my experiments end up.
ps. Those diffraction gratings are the bomb! I should have bought a dozen.
Likes Andy Resnick and davenn
In what way are they not Yellow? There is nothing more special about colours that have come from near monochromatic sources and those that come from a wide mix of wavelengths. 'Yellowness' is an entirely subjective thing and is the result of a very crude analysis that is done on our retina. I say "crude" but that doesn't mean it's bad. As I wrote previously, it's enough to give humans a good survival capability. Our eyes are not spectrometers.
Likewise, you cannot make any 'spectral' comparisons between TV images because the TV sensor is not a spectrometer, either. Once the three broadband sensors have done their work, the spectral information has been totally lost and you are working in colour space. However hard you try, your TV (or any other display technology) will never reproduce spectral yellow and your new toy will show you that - a gap where yellow ' ought to be'. :-p I wonder how long it will be before you realize a spectroscope is only half way there and that you will have to spend at least ten times as much on a spectrometer? I would fancy one but where would I put it?
Personally, I blame our primary school teachers who gave us powder paints to mix together and 'explained' the rules. That was one of the first bits of Wrong Science that we were taught and which we have to un-learn. Having said that, I did love Miss Cree, who was about 100yrs old, scary and ugly as sin. But she comes to my mind almost every day, still, more than sixty years later and gave the the idea that you have to work at things.
Likes OmCheeto
I'll remember to say "spectral yellow", next time. :redface:
:thumbup:
I'm working on a workaround for that.
I realized that, while laying in bed, thinking about my comment. :redface:
It's the same thing with most things in science, IMHO. It was just last year that I discovered that 1/2 mv2 ≠ mgh.
Reminds me of my 4th grade teacher, Ms. Norse. As far as I can remember, I would get bad grades, just so I would have to stay after school, as punishment(Ha!), just to listen to her speak. :bow:
FAQ: Perceived Color of objects: in White light from a TV
1. What is the perceived color of an object in white light from a TV?
The perceived color of an object in white light from a TV depends on various factors such as the color temperature of the light, the characteristics of the object's surface, and the sensitivity of the human eye. It can range from a subjective interpretation of color to an objective measurement using colorimetry.
2. How does the color temperature of the light affect the perceived color of objects?
The color temperature of light refers to the color appearance of light emitted by a blackbody radiator at a particular temperature. It affects the perceived color of objects by influencing the amount and distribution of light that is reflected from the object's surface, which in turn affects the color sensation received by the human eye.
3. Can the perceived color of objects change when viewed under different light sources?
Yes, the perceived color of objects can change when viewed under different light sources. This is because different light sources emit light with different color temperatures and spectral power distributions, which can alter the way an object's color is perceived by the human eye.
4. How is the perceived color of objects measured using colorimetry?
Colorimetry is a scientific method used to measure the perceived color of objects. It involves using a spectrophotometer to measure the reflectance or transmittance of light from an object's surface. This data is then compared to standard color values to determine the object's color characteristics such as hue, saturation, and brightness.
5. What is the role of the human eye in perceiving the color of objects in white light from a TV?
The human eye plays a crucial role in perceiving the color of objects in white light from a TV. It contains specialized cells called cones that are responsible for detecting and interpreting color. These cones are sensitive to different wavelengths of light, and their response to light is what allows us to see different colors. The sensitivity of these cones can also vary from person to person, resulting in differences in color perception.
