Percent Change in Concentration
In summary: Well I'd say that 368 ppm by volume will mean 368 m3 in 1000000 m3. Now that you know the volumes, use the density to find out the amount of CO2 by weight in air. (density = mass / volume)d = m/V = 44.0087/368 = 0.1196 g/m^3new concentration = 0.1196 + 000156 = 0.12116(new-old)/old * 100 = 1.3%
henry3369
194
The world burns approximately 3.8 x 1012 kg of fossil fuel per year.
1. Use the combustion of octane as the representative reaction and determine the mass of carbon dioxide (the most significant greenhouse gas) formed per year.
2. The current concentration of carbon dioxide in the atmosphere is approximately 368 ppm (by volume). By what percentage does the concentration increase each year due to fossil fuel combustion? Approximate the average properties of the entire atmosphere by assuming that the atmosphere extends from sea level to 15 km and that it has an average pressure of 381 torr and average temperature of 275 K. Assume Earth is a perfect sphere with a radius of 6371 km.
Volume of a sphere = (4/3)π(r3)
Percent change = (new - old)/old * 100
I already calculated #1.
1. 1.2 x 10^6 g
2. Vatm = Vearth+atmosphere - Vearth
Vatm = (4/3)π(63863 - 63713) = 7.66899 x 109 km3 = 7.66899 x 1018 m3
368 ppm = 368 g/m3
Using mass obtained from #1, and finding concentration of the increase in CO2:
1.2 x 1016g/7.66899 x 1018 m3 = 0.001564743 g/m3
New concentration = 368 + 0.001564743
Percent change = (new-old)/old * 100 = 0.00042519%
So the answer is 0.42%, and it seems that the way to achieve this is to have the Vatm = 7.66899 x 1015 m3 rather than 7.66899 x 1018 m3. Is there an error in my volume calculation that I am not catching?
1. 1.2 x 10^6 g
368 ppm = 368 g/m3
I didn't go through the entire calculation. But it says 368 ppm by volume, for which you've taken 368 g/m3. But 'g' is a unit of mass. Check that part.
I looked up ppm to g/m^3 and a website told me it was a 1:1 conversion. Can you please tell me what I'm supposed to convert ppm to? I'm familiar with the term.
This is incorrect though. What am I doing incorrectly?
Why do you assume 1 mole of carbon dioxide occupies 368 cubic meters? Just because there are 368 m3 per 1000000 m3? Would you assume volume of 0.368 m3 if you were told 386 ppm means 0.368 m3 in 1000 m3?
Related to Percent Change in Concentration
What is percent change in concentration?
Percent change in concentration refers to the difference between the initial concentration of a substance and the final concentration, expressed as a percentage of the initial concentration.
How is percent change in concentration calculated?
The formula for calculating percent change in concentration is: (final concentration – initial concentration) / initial concentration x 100%. This will give you the percentage change in concentration.
Why is percent change in concentration important?
Percent change in concentration is important because it allows us to quantify the amount of change in concentration of a substance in a given situation. It is commonly used in scientific experiments and studies to track changes in concentration over time.
What factors can affect percent change in concentration?
The factors that can affect percent change in concentration include initial concentration, final concentration, time, temperature, pressure, and any chemical reactions that may occur.
How is percent change in concentration used in real-world applications?
Percent change in concentration is used in various real-world applications, such as in environmental monitoring to track changes in pollutant concentrations, in medicine to measure the effectiveness of a drug, and in economics to analyze changes in market trends and prices.
  • Mechanical Engineering
11K
16K
  • Science Fiction and Fantasy Media
