Percentage of known energy in the Universe
In summary, the known energy in the Universe is comprised of approximately 5% ordinary matter, 27% dark matter, and 68% dark energy. Ordinary matter includes all the atoms that make up stars, planets, and living beings, while dark matter and dark energy are mysterious components that influence the Universe's structure and expansion, respectively. Despite extensive research, the exact nature of dark matter and dark energy remains largely unknown, highlighting significant gaps in our understanding of cosmic composition.
mister i
TL;DR Summary
It is said that the universe is made up of approximately 4.9% ordinary matter, 26.8% dark matter and 69.3% dark energy. Why isn't ordinary energy included in this "pie"?
It is said that the universe is made up of approximately 4.9% ordinary matter, 26.8% dark matter and 69.3% dark energy. Why isn't ordinary energy included in this "pie"? I suppose it is included within ordinary matter, but could it be calculated what % are particles with mass and what % is pure known energy?
Space news on Phys.org
"Pure energy" is a science fiction concept, not a physics one.
The mass of composite particles is not the same as the sum of the masses of their constituent particles, it is true. But you can't divide that into "particles" and "energy" in any meaningful way because mass is not an additive quantity.
Likes phinds
What do you mean by "ordinary energy"? What do you mean by "pure known energy"?
If you mean radiation, that is a tiny fraction of a percent of the total and is not usually included in such breakdowns for that reason. But neither "ordinary energy" nor "pure known energy" are good descriptions of radiation.
My knowledge of physics is very limited, for example I don't know if kinetic energy could have an equivalence with matter through the formula ##m=E/c^2##. If it does, then my common sense tells me that it must be very large since there are billions of billions of stars moving at high speeds in the universe.
Kinetic energy can be a contribution to mass when there is kinetic energy in the center of mass rest frame. As a fraction of total energy, it is ##1-\sqrt{1-v^2/c^2}##, which is approximately ##v^2/2c^2##. For typical speeds of astronomical objects it's utterly negligible (sixth decimal place at least).
Likes PeterDonis
mister i said:
common sense
What people refer to as “common sense” generally provides very poor guidance to the physics of extreme objects (such as the entire universe). It is developed from everyday experience and we have very little everyday experience with extreme objects. There is no a priori reason to believe it should be possible to extrapolate.
mister i said:
TL;DR Summary: It is said that the universe is made up of approximately 4.9% ordinary matter, 26.8% dark matter and 69.3% dark energy. Why isn't ordinary energy included in this "pie"?
As others have noted, "pure energy" isn't a thing.
The ordinary matter category is predominantly the mass of atoms which is 98-99% strong force binding energy and 1-2% quark and electron mass. Strong force binding energy is subsumed in the ordinary matter figure. There is a tiny percentage which represents neutrinos, aggregate kinetic energy, and electroweak sources of mass-energy such as molecular binding energy, photons traveling at any given moment from one place to another and the ephemeral "on shell" weak force carrier bosons that exist at any given moment, all of which would usually be included in the ordinary matter category. All of these sources of "ordinary matter" mass combined are smaller than the combined uncertainty in the dark matter and dark energy category amounts. The last time I looked, the uncertainty in the dark energy category was about ± 2% of the total combined amount in all three categories.
The biggest quantitative theoretical uncertainty in the ordinary matter category is probably the differences between plausible definitions of ordinary mass arising from the difference between the sum of the masses of individual objects in gravitationally bound systems and the mass of a gravitationally bound system as a whole, due to general relativity. Implicitly, due to the way the total ordinary mass is calculated, I believe that the later definition is used, but I'm not deeply immersed in how that is calculated.
Dark energy is calculated as a function of the value of the cosmological constant and the volume of the observable universe. There are several different ways that aggregate dark matter mass is inferred (which more or less converge on the same value).
Likes Klystron
I believe you are correct, at least to the extent that the difference is large enough to matter.
Likes ohwilleke
Kinetic energy is relative, not absolute. I you get hit by a ball that is speeding towards, you, it hurts because the ball's kinetic energy, relative to you, pushed the ball against you. If, on the other had, you are on a flat car that is going at the same speed as the ball, then the ball won't even catch up with you, and it it did it would just fall directly to the floor of the flatcar.
What would you use as the reference point for all those billions of stars?
In a flat space time the internal kinetic energy of a system is an invariant. As you point out, you get hurt by a ball that is speeding toward you. The hurt is the same (invariant) regardless of whether you are moving toward the ball or the ball is moving toward you.
All of the other stars.
However, on a cosmological scale in an expanding universe, relative velocity is a slippery concept. The kinetic energy of relative motion is slippery as well. If two objects are outside of each other's cosmological horizons then their relative velocity or relative kinetic energy are both meaningless.
FAQ: Percentage of known energy in the Universe
What is the percentage of known energy in the Universe?
The percentage of known energy in the Universe is estimated to be about 5%. This includes all the ordinary matter that makes up stars, planets, and living organisms.
What constitutes the remaining percentage of energy in the Universe?
The remaining percentage of energy in the Universe is composed of dark energy (approximately 68%) and dark matter (about 27%). Dark energy is thought to be responsible for the accelerated expansion of the Universe, while dark matter interacts with ordinary matter through gravity but does not emit light.
How do scientists determine the percentage of known energy in the Universe?
Scientists determine the percentage of known energy in the Universe through various observational methods, including studying the cosmic microwave background radiation, galaxy distribution, and gravitational lensing. These observations allow researchers to infer the amounts of dark matter and dark energy present in the Universe.
Why is it important to understand the percentage of known energy in the Universe?
Understanding the percentage of known energy in the Universe is crucial for cosmology and astrophysics, as it helps scientists comprehend the overall structure, evolution, and fate of the Universe. It also informs theories about the fundamental forces and particles that govern cosmic phenomena.
Are there any ongoing studies to refine the percentage of known energy in the Universe?
Yes, ongoing studies and missions, such as the Planck satellite and various ground-based observatories, continue to refine our understanding of the Universe's composition. These efforts aim to provide more precise measurements of dark energy and dark matter, which could lead to new insights into the fundamental nature of the Universe.
