Percentage Uncertanty and youngs modulus
  • Thread starter Thread starter pandit bandit
    Modulus
To find the percentage uncertainty in d^3, the user has calculated the percentage uncertainty for the thickness of the strip as approximately 1.52%. They are unsure how to proceed with the uncertainties of the other measurements, specifically the mass and width. The user suggests that since the calculation involves d^3, the percentage uncertainty should be multiplied by three. The discussion highlights the importance of understanding propagation of uncertainty in calculations involving multiple variables. Clarification on how to combine the uncertainties for all measurements is needed to complete the solution.
pandit bandit
hi there! I am new to this forum and was just wondering if anyone could help with this question on percentage uncertainty. I am supposed to find the percentage uncertainty in d^3
the info given is
mass attached to the end of a strip= 0.1 (+-0.001)kg
the width of the strip = 12.6 (+- 0.1)mm
the thickness of the strip= 0.66(+- 0.01)mm
I am also given the equation for youngs modulus
E= 16pi^2 K^2 M/bd^3
I worked out the percentage uncertainty of the thickness of the strip which was approx. 1.52% but am for completely lost:confused:
Thank You!
so would i just simply multiply the percentage uncertainty by 3 as its d^3?
Sure, I'd buy that.
12K
  • · Replies 18 ·
9K
