Performing a Taylor Series Expansion for Lorentz Factor
In summary: I get it now!In summary, to perform a Taylor Series expansion for γ in powers of β^2, keeping only the third terms, we can expand (1-β^2)^(-1/2) in powers of β^2 and substitute 0 for x, resulting in the formula: Tf(β^2;0) = 1 + (1/2)β^2 + (3/8)β^4 + ....
Kunhee
51
Perform a Taylor Series expansion for γ in powers of β^2, keeping only the third terms (ie. powers up to β^4). We are assuming at β < 1.
γ = (1-β^2)^(-1/2)
I have no background in math so I do not know how to do Taylor expansion. Could you help me out? Thank you very much.
Have you looked up Taylor series in Wikipedia?
Here is a link to the formula, which is clearer than on the English version. Just look at the formula.
Which brings me to the next question. Do you know how to differentiate a / your function (with respect to ##\beta##)?
Likes Kunhee
Sorry, I am not sure. I have been away from all maths for a long time.
But could you help me out? What is my x and a?
Your ##f## is ##\gamma## and your ##x## is ##\beta##. Unfortunately you didn't specify what your ##a## is, so I assume it is ##a=0##.
If not mentioned otherwise it's almost always ##0##. But some functions aren't defined at ##0##. In these cases one cannot "automatically" take zero. However, your function is defined in ##0## and your ##x = \beta## is assumed smaller than one, so ##a=0## should be ok.
Edit: don't forget the internal differentiation: ##\gamma' = \frac{d}{d \beta} (1- \beta^2)^{-\frac{1}{2}} = -\frac{1}{2}(1- \beta^2)^{-\frac{3}{2}} \, \cdot \, (-2 \beta)##
Okay I am solving it, one moment please!
https://wikimedia.org/api/rest_v1/media/math/render/svg/132e57acb643253e7810ee9702d9581f159a1c61 is γ = (1-β^2)^(-1/2)
x = β
and a = 0 so therefore my equation would look like this:
T [PLAIN]https://wikimedia.org/api/rest_v1/media/math/render/svg/132e57acb643253e7810ee9702d9581f159a1c61(x[I][I][I];a) = [PLAIN]https://wikimedia.org/api/rest_v1/media/math/render/svg/132e57acb643253e7810ee9702d9581f159a1c61(a) + [PLAIN]https://wikimedia.org/api/rest_v1/media/math/render/svg/132e57acb643253e7810ee9702d9581f159a1c61'(a) (x-a) + [[PLAIN]https://wikimedia.org/api/rest_v1/media/math/render/svg/132e57acb643253e7810ee9702d9581f159a1c61''(a) / 2 ] (x-a)^2 + [[PLAIN]https://wikimedia.org/api/rest_v1/media/math/render/svg/132e57acb643253e7810ee9702d9581f159a1c61'''(a) / 6] (x-a)^3 ...[/I][/I][/I]
T [PLAIN]https://wikimedia.org/api/rest_v1/media/math/render/svg/132e57acb643253e7810ee9702d9581f159a1c61([I][I]β[I];0) = [PLAIN]https://wikimedia.org/api/rest_v1/media/math/render/svg/132e57acb643253e7810ee9702d9581f159a1c61(0) + [PLAIN]https://wikimedia.org/api/rest_v1/media/math/render/svg/132e57acb643253e7810ee9702d9581f159a1c61'(0) (x-0) + [[PLAIN]https://wikimedia.org/api/rest_v1/media/math/render/svg/132e57acb643253e7810ee9702d9581f159a1c61''(0) / 2 ] (β-0)^2 + [[PLAIN]https://wikimedia.org/api/rest_v1/media/math/render/svg/132e57acb643253e7810ee9702d9581f159a1c61'''(0) / 6] (β-0)^3 ...
[/I][/I][/I]
I am stuck here. I can find each derivative of (1-β^2)^(-1/2) but there is nowhere to plug in "a" in this
function. I apologize if I am making a very dumb mistake. Thanks for the help.
Better: take ##x = \beta^2##. Expand ##(1-x)^{-1/2}## in powers of ##x##, then put ##x = \beta^2## later. That makes finding the needed derivatives a lot easier.
Likes fresh_42
I see, thanks. That's what the question meant!
But I am still confused at how a = 0 fits into this equation.
Looking at the equation, the functions do not have anywhere to plug in for a.
If your "##a##" refers to the formula
$$f(x) = f(a) + f'(a) (x-a) + \frac{1}{2!} f''(a) (x-a)^2 + \cdots, $$
then you are dealing with the case ##a = 0##
If you take ##\gamma(x) = (1-x)^{-\frac{1}{2}}## then ##\gamma'(x) = \frac{1}{2}(1-x)^{-\frac{3}{2}}## and ##\gamma'(0) = \frac{1}{2}(1-0)^{-\frac{3}{2}} = \frac{1}{2}##. Don't forget that there is a factor ##(x-a)^1= (x-0)^1=x##, too. (In the second term of the series.)
Just a quick question...
When do we use γ and when do we use its reciprocal α when solving for coordinates of S' frame through Lorentz transformations?
My teacher used the reciprocal but my textbook uses γ in the same equation and my length contraction is actually going reverse and
getting longer.
Solving...
Yes. But you want to expand at ##a=0##, that is in the formula ##f^{(n)}(a)=f^{(n)}(0)##. So you have to substitute ##0## where ##x## was or ##\beta## is. And the exponents are still negative (although it doesn't matter in this case). You multiply with ##(x-a)^n=(x-0)^n=x^n=\beta^{2n}##. The differentials of ##f=\gamma## are evaluated at ##0##, not extra multiplied.
So the first term of the sum is ##f(0)x^0 = 1## the second ##f'(0)x^1=\frac{1}{2}x## the third ##\frac{1}{2}f''(0)x^2=\frac{3}{8}x^2## and so on.
Edit: Remember the formula is (with ##f=\gamma## and ##x=\beta^2##) ##\; Tf(x;0)= f(0)+f'(0)x+\frac{f''(0)}{2}x^2+\frac{f'''(0)}{6}x^3+ \dots##.
Likes Kunhee
Thanks so much...
Related to Performing a Taylor Series Expansion for Lorentz Factor
What is a Taylor Series Expansion?
A Taylor Series Expansion is a mathematical method used to approximate a function by a polynomial, using information about the function at a single point and its derivatives. It is often used to find an approximation of a function at a point that is near a known point.
What is the Lorentz Factor?
The Lorentz Factor is a term used in special relativity to describe the relationship between an object's velocity and its mass and energy. It is represented by the Greek letter gamma (γ) and is used to calculate how much an object's mass and length change as it moves at high speeds.
Why is a Taylor Series Expansion used for Lorentz Factor?
A Taylor Series Expansion is used for Lorentz Factor because it allows for an accurate approximation of the Lorentz Factor at high velocities. This is important in understanding the effects of special relativity, such as time dilation and length contraction, which occur at high velocities.
What is the process for performing a Taylor Series Expansion for Lorentz Factor?
The process for performing a Taylor Series Expansion for Lorentz Factor involves taking the derivative of the Lorentz Factor function, evaluating it at the known point, and then plugging in the values for the point and its derivatives into the Taylor Series formula. This will give an approximation of the Lorentz Factor at the desired point.
What are the limitations of using a Taylor Series Expansion for Lorentz Factor?
The limitations of using a Taylor Series Expansion for Lorentz Factor include the assumption that the function is smooth and continuous, as well as the accuracy of the approximation decreasing as the distance from the known point increases. It is also important to note that the Taylor Series Expansion is only an approximation and may not give an exact value for the Lorentz Factor.
