Period of a pendulum with two masses.
In summary, the conversation discusses a problem involving a light rigid pendulum with two masses, one placed at the end and one placed at a distance from the pivot. The conversation includes equations and an attempt at solving the problem using the center of mass and small angle approximation, but it is later discovered that this approach is incorrect. The conversation recommends looking at a general formula for the period of a physical pendulum and considering the potential and kinetic energy of the system to solve the problem.
1bigman
We have a light rigid pendulum with length ##l##. A mass ##M## is placed at the end and a mass ##m## is placed a distance ##x## from the pivot. What is the period of the pendulum?
Reduce the problem to a single mass situation using the center of mass. From the pivot, I get the center of mass ##r = \frac{mx+Ml}{m+M}##
Using the small angle approximation we end up with ##\frac{d^2\theta}{dt^2} + \frac{g(M+m)}{mx + Ml} \theta = 0## and hence ## T = 2\pi \sqrt{\frac{mx + Ml}{g(M+m)}}##
I suspect this is incorrect as the second part of the questions asks for the value of ##x## which has the greatest impact on ##T## which cannot be obtained as ##\frac{dT}{dx} = 0 ## has no solutions in ##0<x<l##. Help is much appreciated.
Problems like this are usually given after a discussion of the "physical pendulum" as opposed to the "simple pendulum". So, you might check your notes or text to see if a general formula for the period of a physical pendulum is given. Or see http://hyperphysics.phy-astr.gsu.edu/hbase/pendp.html
The 2 masses cannot be reduced to a single mass at the centre of mass. This is because the inertia of the system is dependant of the moment of inertia of the 2 masses (Which is different to that of 1 mass at the centre of mass).
If you haven't seen this before, take a look at this: http://hyperphysics.phy-astr.gsu.edu/hbase/pendp.html
If you are yet to visit moment of inertia, consider the potential and kinetic energy of the system (V+T)=E. By differentiating with respect to time and setting dE/dt to 0, the equation of motion can be obtained.
Ah yes of course! Many thanks for the help guys!
Related to Period of a pendulum with two masses.
1. How is the period of a pendulum with two masses calculated?
The period of a pendulum with two masses can be calculated using the equation T = 2π√(l/g), where T is the period in seconds, l is the length of the pendulum in meters, and g is the acceleration due to gravity in m/s².
2. What factors affect the period of a pendulum with two masses?
The period of a pendulum with two masses is affected by the length of the pendulum, the mass of the masses, and the acceleration due to gravity. It is also affected by any external factors, such as air resistance, that may alter the motion of the pendulum.
3. How does changing the length of the pendulum affect the period?
According to the equation T = 2π√(l/g), the period of a pendulum with two masses is directly proportional to the square root of the length of the pendulum. This means that as the length of the pendulum increases, the period also increases.
4. Are there any real-life applications of a pendulum with two masses?
Yes, pendulums with two masses are commonly used in clocks and metronomes to keep time. They are also used in seismometers to measure earthquakes, and in amusement park rides to create the swinging motion.
5. How is the period of a pendulum with two masses affected by the mass of the masses?
The period of a pendulum with two masses is not affected by the mass of the masses. This is because the mass cancels out in the equation T = 2π√(l/g), making it independent of the mass.
