Periodic Boundary Conditions and which Hamiltonian to use
In summary: so basically you guessed at the general form of the wavefunction without understanding why it works.
rwooduk
762
59
Example Question: an electron with mass m is confined in a thin wire, with periodic boundary conditions applied in the x direction and harmonic potentials in the y and z direction. Write an expression for the wave functions in the ground state. Write down all the energy eigen values.
Schrodinger Equation
0=0
I have no trouble deriving the wave function for the periodic boundary conditions.
Question:
1. I've used the same method to derive the harmonic potential wave functions as a simple harmonic oscillator, are they the same?
2. I'm having real trouble with knowing the hamiltonian to use for periodic boundary conditions. I (now) understand that the only thing that changes in the hamiltonian for a system is the potential term (and time depencancy). However what would the potential term be for a periodic boundary condition system?
This is a revision question for exams (not assessed).
Thanks in advance for any guidance on this.
... these two statements seem to contradict each other: how can you "derive" the wavefunction if you don't know the Hamiltonian? Have you tried doing it backwards - work from the wavefunction to the Hamiltonian?
Say the wire is length L, what is the potential inside the length L?
Put V= that potential in the schrodinger equation and you have your Hamiltonian.
... yes.
You should have something about this in your notes - it's just like when you saw a 3D particle in a box, you took infinite square-well wavefunctions, independently, in each direction.
Hi, I derived the wavefunction for the periodic conditions by starting with the general form X(x) = A sin kx + B cos kx = A exp (ikx) + B exp (-ikx) and then applying the boundary conditions X(L) = X(0) for B=0 etc. I derived the wavefunction for the harmonic oscillator by applying the annihilation operator to an unknown ground state wave function Y(y).
This is what I'm struggling with, how would you know that potential? I could derive the potential at a point r in the wire using last years electromagnetism, but I'm sure that would not be the right way to do it. I really have a mental block with this. Also, other questions simply say the system is periodic, is there a general potential for this case?
Simon Bridge said:
... yes.
Excellent, yes I see now, thanks!
... so basically you guessed at the general form of the wavefunction without understanding why it works.
You know what sort of potential gives rise to HO solutions - what sort of potential would normally have the sine/cosine solutions?
... in this case you would want to model the wire as a perfect conductor with no internal structure.
Consider: the infinite square well is the model for a block of conducting material where the walls perfectly reflect.
If you took a long thin bit of such a material, then joined the ends together, what would the boundary conditions be like?
to be honest you are right, I had always assumed that since the particle could be considered a wave then X(x) = A sin kx + B cos kx is used as it's a solution to the wave equation, is that not correct? the solution would also be of the sine/cosine form. A free particle / wave where there was no potential and a confined particle / wave where there was an infinite potential would both give sine/cosine solutions. In fact thinking about it wouldn't all potentials give sine/cosine solutions in one form or another.
the solution would take integer values i.e. a certain number of wavelenths would "fit" into the wire, not sure how you would describe this as a boundary condition.
thanks for the help
Not in general, no.
1. It is not useful at this stage to think of the particle as a wave.
2. X (x) given above is not the solution to the HO potential.
The free particle wave function is ##\psi (x) = 1## ... a beam of particles would normally be modeled by plane-waves.
You need to get used to writing a physical situation in maths. You can probably sketch it using your intuition for standing waves... its the same as the harmonics on the rim of a bell. When you do the sketch, you start out assuming some value at some point, then follow that assuption to its logical conclusion. Same with the maths.
A boundary condition can relate values in one part of the wire to another.
If x is a distance around the wire from some reference point, then x=L is the same place as x=0.
How would you write the relationship between the wavefunction at these two coordinates?
Simon Bridge said:
Not in general, no.
2. X (x) given above is not the solution to the HO potential.The free particle wave function is ##\psi (x) = 1## ... a beam of particles would normally be modeled by plane-waves.You need to get used to writing a physical situation in maths. You can probably sketch it using your intuition for standing waves... its the same as the harmonics on the rim of a bell. When you do the sketch, you start out assuming some value at some point, then follow that assuption to its logical conclusion. Same with the maths.
Great, many thanks for the insight! To answer your question it would be Ψ(0) = Ψ(L) but can't see how that would help me determine the potential for the wire?
thanks again
... also ##\frac{\partial}{\partial x}\psi(0) = \frac{\partial}{\partial x}\psi(L)## : the amplitude and gradient have to be the same.
It does not help you find the potential - sorry: I was expecting you to recognize the periodic boundary conditions ;)
What tells you the potential inside the wire is that it is a (classically ideal) conductor.
Think back to classical electrostatics: what is the electric potential inside any conductor?
ahh ok thanks! and classically? it's constant, just kQ/r would this fit to the potential term in the Hamiltonian?
just to recap (for myself and anyone reading) I'm trying to find the potential term for the Hamiltonian for a wire, so that it may be applied to the wave function already derived from periodic boundary conditions.
Does anyone else have any ideas of what form of Hamiltonian you would use given the wave function of a periodic system, such as a wire?
the closest thing I've found is this:
http://rci.rutgers.edu/~ke116/Teaching_files/bloch.pdf
but I'm pretty sure the question just wants a simple expression for the potential.
My interpretation of the problem is that you have a particle that is free to move along the length of the wire (along the x axis, 0<x<L). But the particle is not free to move in directions perpendicular to the axis of the wire (y and z direction). Being "free" along the x-axis should tell you something about the x-dependence of the potential energy function. Likewise, "harmonic" in the y and z directions tells you about the y and z dependence of the potential energy function. You should be able to write a mathematical expression for the potential energy function V(x, y, z) based on this information. Then you can write down the complete Hamiltonian.
Note that you are also supposed to impose a periodic boundary condition in the x direction on the wave function. This periodic boundary condition on the wavefunction is used to help write the expressions for the wavefunctions. But this boundary condition is not used to construct the form of the Hamiltonian.
No, that would be the potential for a point charge.
You need to review classical electrostatics.
What is the potential inside a conductor?
inside a conductor its constant, but there is no numerical value given in the question. i think i see where this is going, if it is "free" then there would be no potential so effectively the potential term would be zero. does that sound correct?
thanks for the replies!
Free to move in the x direction means that there is no x-component of force acting on the particle. So, the potential energy will not depend on x. However, the particle is trapped inside the wire by y and z components of force. "Harmonic potentials in the y and z directions" means that these force components are modeled as obeying Hooke's law. This should tell you how the potential energy depends on the y and z coordinates. Think harmonic oscillator.
So is the potential just a constant or zero in the x direction? if it's a constant no numerical vlaue is given in the question so how would i obtain a numerical value for the eigen value? yes, thanks already applied the Hamiltonian for a SHO to the y and z eigen states.
You can just take the potential energy of the particle to be independent of x and zero for all points on the x-axis in the region 0 < x < L.
Since no numbers are given, you will express your answers in terms of parameters such as the mass of the particle, the length of the wire, and the "force constant" of the harmonic potential.
You should find that Schrodinger equation can be solved by separation of variables: ##\psi(x, y, z) = X(x)Y(y)Z(z)##.
Likes rwooduk
Ok that's great, thanks everyone for all the help with this question!
I'm going to complete this thread after getting confirmation from the lecturer... "There is no potential term. The Hamiltonian is only equal to the kinetic term (there is no approximation in this statement). "
Related to Periodic Boundary Conditions and which Hamiltonian to use
1. What are Periodic Boundary Conditions?
Periodic Boundary Conditions (PBCs) are a set of boundary conditions commonly used in computational simulations of physical systems. They allow for the simulation of an infinite system by creating a periodic repetition of the simulation cell, ensuring that the system remains consistent and does not encounter any artificial boundary effects.
2. Why are Periodic Boundary Conditions important in scientific simulations?
PBCs are important because they allow for the simulation of larger and more realistic systems, which can provide more accurate results. They also mimic the behavior of real physical systems, where atoms or molecules interact with their periodic images in a periodic lattice.
3. How do Periodic Boundary Conditions affect the Hamiltonian used in simulations?
Periodic Boundary Conditions do not affect the Hamiltonian directly, but they do affect the boundary conditions applied to the system, which in turn can affect the Hamiltonian. For example, PBCs can change the range of interactions between particles, leading to different Hamiltonians being used in simulations.
4. What is the difference between using PBCs and non-periodic boundary conditions?
The main difference between PBCs and non-periodic boundary conditions is that PBCs allow for the simulation of an infinite system, while non-periodic boundary conditions simulate a finite system with explicit boundaries. PBCs also require the use of specialized algorithms to account for the periodicity of the system, while non-periodic boundary conditions do not.
5. How do I choose which Hamiltonian to use with Periodic Boundary Conditions?
The choice of Hamiltonian depends on the specific system being simulated and the research question being addressed. It is important to consider the interactions present in the system and choose a Hamiltonian that accurately captures these interactions. Additionally, some Hamiltonians may be better suited for use with PBCs, so it is important to consult the literature and seek guidance from experienced researchers in the field.
