MHB Periodic Function: Prove Smallest Positive Period
  • Thread starter Thread starter Andrei1
    Function Periodic
The function f(x) = tg(11x/34) + ctg(13x/54) has a period of 918π, which is the least common multiple of the individual periods of its components. The tangent function repeats every 34π/11 and the cotangent every 54π/13. To prove that 918π is the smallest positive period, one must examine the points where the function becomes undefined, which occur at specific intervals that do not repeat before 918π. This analysis shows that no smaller period can satisfy the conditions of the function. Thus, 918π is confirmed as the smallest positive period of f.
Andrei1
One period of the function $$f(x)=\operatorname{tg}\frac{11x}{34}+\operatorname{ctg}\frac{13x}{54}$$ is $$918\pi.$$ Please help me to prove that this is the smallest positive period. I can not use the most of trigonometric identities.
Mathematics news on Phys.org
The tangent and cotangent functions both have period $\pi$. So the function $\tan\frac{11x}{34}$ will repeat at intervals $\frac{34\pi}{11}$, and $\cot\frac{13x}{54}$ will repeat at intervals $\frac{54\pi}{13}$. You need to find the least common multiple of those two intervals.
$$T=918\pi$$ is the least common multiple of those periods. I found this. But why it is the smallest positive period of $$f$$?
For example, I consider the functions $$f_1(x)=\sin x$$ and $$f_2(x)=\operatorname{tg} x-\sin x$$, which both have $$2\pi$$ as main period. But then $$\pi$$ is the main period of $$f_1+f_2$$, which is not the least common multiple of $$2\pi.$$
You could look at the set of points at which $f(x)$ becomes infinite (or is undefined). That will happen at the points $x = \bigl(\frac{34}{11}k + \frac12\bigr)\pi$ and $x = \frac{54}{13}k\pi$ (and nowhere else). I think you should find that that set of points does not repeat at intervals of less than $918\pi$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
