Periodicity of Fourier's heat theory
In summary, Fourier developed his idea of heat transfer being a periodic phenomena based on the solutions of the wave equation which arise from separation of variables.
jaredokie
Can I please get some help in understanding how Fourier developed his idea of heat transfer being a periodic phenomena?
I don't know what you mean by that. Heat is NOT a "periodic phenomenon" and Fourier never said it was. You may be mistaking Fourier series (infinite sums of sine and cosine) with finite sums. Finite sums of periodic functions are periodic. Infinite sums are not.
So why did he use sine and cosine functions for heat analysis? Orthogonal reasons?
Because sine and cosine are the solutions of the equations for the spatial variation which arise from separation of variables in the heat equation.
Ok. I'm sorry for being dense, but what do you mean by spatial variation?
The wave equation is
[tex]\frac{\partial^2 \phi}{\partial x^2}= \frac{1}{c^2}\frac{\partial^2\phi}{\partial t^2}[/tex]
If you use "separation of variables" you would look for solutions of the form [tex]\phi(x, t)= X(x)T(t)[/tex] (separating x and t into separate functions) so that the equation becomes
[tex]T\frac{d^2X}{dx^2}= \frac{1}{c^2}X\frac{d^2T}{dt^2}[/tex]
Divide both sides by XT to get
[tex]\frac{1}{X}\frac{d^2X}{dx^2}= \frac{1}{c^2T}\frac{d^2T}{dt^2}[/tex]
Now the left side is a function of x only and the right side is a function of t only. In order to be the same for all x and t, each side must be equal to a constant:
[tex]\frac{1}{X}\frac{d^2X}{dx^2}= \lambda[/tex]
[tex]\frac{d^2X}{dx^2}= \lambda X[/tex]
This is what pasmith is referring to as the "spatial variation".
IF we are given the heat problem on a finite interval, say T(0)= T(P)= 0, then we can show that the "spatial dependence", the function X(x), must have sine and cosine solutions.
If, for example, [itex]\lambda= 0[/itex] this becomes just [itex]d^2X/dx^2= 0[/itex] so the general solution is y= Ax+ B which is NOT periodic and so cannot satisfy the boundary conditions.
If, for example, [itex]\lambda> 0[/itex] the general solution is [itex]y= Ae^{x\sqrt{\lambda}}+ Be^{x\sqrt{\lambda}}[/itex].
So [itex]\lambda[/itex] must be negative. If we write [itex]\lambda= -\alpha^2[/itex], the equation becomes [itex]d^2X/dx^2= -\alpha^2 X[/itex], which has general solution [tex]Acos(\alpha x)+ B sin(\alpha x)[/tex]. That's where the
[tex]\frac{1}{c^2T}\frac{d^2T}{dt^2}= \lambda[/tex]
[tex]\frac{d^2T}{dt^2}= \lambda c^2T[/tex]
Again, that is for the heat problem on a finite interval. If we had and infinite interval, say the heat equation on [itex]x\in [0, \infty)[/itex], the solutions are Fourier Transforms, not Fourier series, and are NOT periodic at all.
FAQ: Periodicity of Fourier's heat theory
What is Fourier's heat theory?
Fourier's heat theory, also known as the theory of heat conduction, is a mathematical model that explains how heat is transferred through a material. It is based on the principles of thermodynamics and was developed by French mathematician Joseph Fourier in the early 19th century.
What is periodicity in Fourier's heat theory?
Periodicity in Fourier's heat theory refers to the phenomenon where heat flow through a material repeats itself at regular intervals. This occurs when the material has a constant temperature gradient and follows a sinusoidal pattern.
How is periodicity related to Fourier series?
Fourier series is a mathematical method used to represent a periodic function as a sum of sine and cosine functions. In the context of Fourier's heat theory, periodicity is achieved when the temperature profile of a material can be accurately represented using a Fourier series.
What is the significance of periodicity in Fourier's heat theory?
The concept of periodicity is crucial in understanding and predicting heat flow through materials. It allows scientists to model and analyze complex heat transfer scenarios, such as in heat exchangers and thermoelectric devices.
Can periodicity be observed in real-world systems?
Yes, periodicity in heat flow can be observed in many real-world systems. For example, the daily temperature fluctuations on the Earth's surface, the heating and cooling cycles of a car engine, and the temperature variations in a building throughout the day are all examples of periodic heat flow.
