Permanent / Electromagnet DIY Query
In summary, when making an electromagnet out of a ferromagnetic material, like neodymium, the current passing through the wire will cause the magnetic field strength to increase to a point, but eventually the core will become saturated and increasing the current will have little effect. This is due to the material's nonlinear magnetic properties. Once the current is stopped, the magnet will still have a little residual magnetism left on it.
dwaring28720
32
To make your own electromagnet simply use an iron nail wrap some copper wiring around it and tape it to a battery fair enough, the current passing through the wire causes a magnetic field...
My question is one of annoyance because my boss won't let me try it with the 100mm Neodymium magnets we have in work, as we know passing a current through a wire will generate a magnetic field, but what will happen to the size of the field if you were to attach a sufficient power supply directly to an already magnetized substance, like the one i have access to in work, would the current passing through it increase the size of the field, or would it simply complete the circuit with no increased performance.
please correct me where I've gone wrong with any of this, I am not a scientist and this is more of a personal interest to me
thanks
A ferromagnetic material, such as neodymium, has nonlinear magnetic properties. But before discussing what would happen when making an electromagnet out of an already fixed magnet, let me back up a bit.
Suppose you take a iron nail and wrap the wire around it and attach it to a battery. The iron nail's ferromagnetic material, acting as the magnetic core, greatly increases the electromagnet's magnetic field strength. But only to a point.
When low currents are run through the wire, the electromagnet's magnetic field strength will be approximately proportional to the amount of current. If you increase the current, you will proportionally increase the magnetic field strength. But eventually, if you increase the current past some point, the magnetic field strength will not follow. The core has become saturated in this case. when the core is saturated, increasing the current doesn't have much of an effect on the magnet's strength.
After driving the core to saturation, suppose you remove the battery. You will find that the iron nail still has a little touch of magnetism left on it. Bring it close to a compass and mark which end of the nail is North and which is South.
Now repeat bringing the electromagnet into saturation, but this time reverse the polarity of the battery. Remove the battery and bring the compass back. You'll see that the iron nail's residual magnetism has reversed polarity.
This process where the core's residual magnetic properties "remembers" what the magnetic field strength was in the past is called magnetic hysteresis (there are some other words to describe the phenomenon too).
The residual magnetism caused by this sort of "memory" isn't very strong, and its not the best way to make a standing magnet. Your neodymium were probably made by melting the neodymium and letting it slowly cool in a high intensity magnetic field. But my point is that using a ferromagnetic material in an electromagnet can change the material's magnetic properties even after the external current has stopped.
Okay, so here's the point of all of that. If you were to take an existing fixed, neodymium magnet and make an electromagnet out of it, here is what would probably happen.
(I) The direction of the wire winding and the polarity of the battery are such that the magnetic flux density reinforces the magnetic field intensity (i.e. the electromagnet characteristic N/S are in the same direction as the standing magnet):
...I'm guessing not much will happen. The standing magnet is already in the point of saturation (as it was designed to be), and making an eltromagnet won't help its magnetic field strength significantly bigger.
(2) The direction of the wire winding and the polarity of the battery are such that the magnetic flux density opposes the magnetic field intensity (i.e. the electromagnet characteristic N/S are in the opposite direction as the standing magnet):
...In this case the magnet's strength will be reduced, at least temporarily. I'm not sure if it would permanently weaken the magnet, but if brought into saturation it might, at least a little. On the other hand, with experimentation, you might be able to use this setup to temporarily turn a standing magnet "off" for awhile. Turn the current on and a magnet acts like a normal piece of metal. Remove the current and it goes back to being a standing magnet again. But again, I'm not positive what effect this would have on the long term life of such a magnet.
interesting, so as the permanent magnets i have are already "saturated", essentially nothing can be gained by inducing a current into them, and depending on the direction of the wire the field could be detrimentally affected if its in the opposite direction to the already established poles.
thanks very much, very clear even for someone of my level of knowledge.
FAQ: Permanent / Electromagnet DIY Query
1. How do I make a permanent magnet at home?
Making a permanent magnet at home is possible, but it requires specific materials and tools. To make a permanent magnet, you will need a ferromagnetic material such as iron, nickel, or cobalt, a strong magnet, and a source of electricity. First, heat the ferromagnetic material until it reaches its Curie temperature, then expose it to a strong magnetic field while it cools down. This process aligns the magnetic domains in the material, creating a permanent magnet.
2. Can I turn an electromagnet into a permanent magnet?
No, an electromagnet cannot be turned into a permanent magnet. An electromagnet works by creating a magnetic field when an electric current passes through a coil of wire. Once the current is turned off, the magnetic field disappears. To make a permanent magnet, the magnetic domains in a material need to be aligned, which cannot be achieved with an electromagnet.
3. What materials can I use to make an electromagnet?
You can use a variety of materials to make an electromagnet, including iron, steel, copper, and aluminum. These materials are known as ferromagnetic materials and are attracted to magnets. The key to making a strong electromagnet is to have a large number of loops in the wire and to increase the current flowing through it.
4. Can I control the strength of an electromagnet?
Yes, you can control the strength of an electromagnet by varying the number of loops in the wire, the amount of current flowing through it, and the material used for the core. The more loops in the wire and the higher the current, the stronger the magnetic field will be. Additionally, using a ferromagnetic material with a high magnetic permeability, such as iron, can also increase the strength of an electromagnet.
5. Are there any safety precautions I should take when making an electromagnet?
Yes, there are a few safety precautions you should take when making an electromagnet. First, make sure to use insulated wire to avoid electric shocks. Also, be careful when handling strong magnets, as they can attract metal objects and cause injury. Finally, be mindful of the amount of current flowing through the wire, as high currents can generate heat and potentially cause a fire.
