Permanent magnet on the surface of a hollow sphere
In summary: Your Name]In summary, the question is about calculating the magnetic flux density of a permanent magnet placed above a hollow iron sphere. The suggested approach is to use the method of images and consider the hollow sphere as a collection of smaller current loops, finding the equivalent current loops that would produce the same magnetic field. This can be done using multipole expansion. More research and guidance on this method is recommended.
baggiano
Hello
I would like to calculate the magnetic flux density given by a permanent magnet which is placed about the surface of a iron hollow sphere (assume mur = Inf). Actually, I am interested in the flux density just outside the hollow sphere.
The idea is to replace the magnet with equivalent volume/surface current densities (or with equivalent volume/surface charge densities) and subsequently apply the method of images. As far as I understand this is quite classical if the magnet is placed above a ferromagnetic infinite plate. However, as the magnet is placed above the hollow sphere I am struggling to figure out how to find the image sources (position and value). I have found a nice example in the Griffiths book (example 3.2) but I am not sure I can directly apply one to one the theory.
Any suggestion? Hints?
Thanks in advance and have fun!
Hello,
Thank you for your question. Calculating the magnetic flux density in this scenario can be approached using the method of images, as you mentioned. However, since the magnet is placed above a hollow sphere instead of a flat plate, the image sources will be different.
One way to approach this problem would be to first consider the hollow sphere as a collection of smaller, infinitesimal current loops. Each of these loops will act as an individual magnetic dipole, with its own magnetic moment and corresponding magnetic field. Then, using the method of images, we can find the equivalent current loops that would produce the same magnetic field as the original magnet.
To do this, we can use the concept of multipole expansion. The magnetic field at a point outside the hollow sphere can be expressed as a sum of contributions from each of the current loops. By setting the magnetic field produced by the equivalent current loops equal to the field produced by the original magnet, we can solve for the position and value of the image sources.
I would suggest looking into multipole expansion and the method of images for more information and guidance on this approach. I hope this helps and good luck with your calculations!
FAQ: Permanent magnet on the surface of a hollow sphere
How does a permanent magnet on the surface of a hollow sphere work?
The permanent magnet on the surface of a hollow sphere works by creating a magnetic field around the sphere. The magnetic field has a north and south pole, and objects with magnetic properties will align themselves with the field.
What materials are used to make a permanent magnet on the surface of a hollow sphere?
The most commonly used materials for making permanent magnets are iron, cobalt, and nickel. These materials have strong magnetic properties and can retain their magnetism for a long period of time.
What is the purpose of a permanent magnet on the surface of a hollow sphere?
The purpose of a permanent magnet on the surface of a hollow sphere is to create a magnetic field that can be used for various applications such as magnetic levitation, motors, and generators. It can also be used for scientific experiments and demonstrations.
Can the strength of a permanent magnet on the surface of a hollow sphere be changed?
The strength of a permanent magnet on the surface of a hollow sphere is determined by the material and shape of the magnet. It cannot be changed unless the material is altered or the shape is modified.
Are there any safety precautions when handling a permanent magnet on the surface of a hollow sphere?
Yes, it is important to handle permanent magnets with caution as they have strong magnetic fields that can attract metal objects and cause injuries. It is also important to keep them away from electronic devices such as credit cards and phones, as the magnetism can interfere with their functioning.
