Permanent marker to decorate a coffe mug
  • Thread starter flatmaster
In summary, people have attempted to decorate coffee mugs with permanent markers by following various techniques, such as letting the mug set for 48 hours before firing it in the oven. The most common technique is to allow the organic solvent to evaporate before firing. However, it is uncertain if the firing temperature of 350F-450F is enough to melt the ink into the glaze. There is currently no new information or findings available.
flatmaster
501
I am looking to decorate some coffee mugs with a permanent marker. People have tried this before and attempted many different techniques for keeping the dried ink on the mug.
http://www.craftaholicsanonymous.net/21-tips-for-diy-sharpie-marker-mugs
The most common technique involves letting the mug set for 48 hours before firing it in the oven. I suppose this allows enough time for all of the organic solvent to evaporate before firing it.
Is the firing temperature of 350F-450F actually enough to melt the ink into the glaze?
Chemistry news on Phys.org
I'm sorry you are not generating any responses at the moment. Is there any additional information you can share with us? Any new findings?
FAQ: Permanent marker to decorate a coffe mug
1. How do I properly prepare a coffee mug for decoration with permanent markers?
To prepare a coffee mug for decoration with permanent markers, make sure it is clean and dry. You can use rubbing alcohol to wipe down the surface of the mug before decorating to remove any oils or residue that may interfere with the markers' ability to adhere to the mug.
2. What type of permanent markers should I use for decorating a coffee mug?
It is important to use oil-based permanent markers specifically designed for use on ceramics or glass. Regular permanent markers may not adhere well to the surface of the mug and may wash off or fade over time.
3. Can I use any type of design or image when decorating a coffee mug with permanent markers?
Yes, you can use any design or image you like when decorating a coffee mug with permanent markers. However, keep in mind that intricate designs or images with a lot of details may be more difficult to achieve with markers and may require more time and patience.
4. How should I care for a coffee mug decorated with permanent markers?
To ensure the longevity of your decorated coffee mug, it is best to hand wash it with mild soap and warm water. Avoid using abrasive sponges or harsh cleaning products, as they may cause the design to fade or scratch off.
5. Can I use a regular oven to set the design on a coffee mug decorated with permanent markers?
No, it is not recommended to use a regular oven to set the design on a coffee mug decorated with permanent markers. The high heat of an oven may cause the design to melt or become distorted. Instead, you can use a toaster oven or a DIY method such as placing the mug in a cold oven and then heating it to 350 degrees Fahrenheit for 30 minutes.
