Permissibility of Limit Technique
  • Thread starter Yitzach
  • Tags
    Limit
In summary: Therefore, we limit the answer to positive real numbers because we want to avoid zero and infinity, which are also solutions to the extended real number equation. Additionally, we want to avoid negative real numbers because they do not make sense in the context of this problem. In summary, the limit in this problem is limited to positive real numbers and the method used to solve it is permissible as long as the answer is checked to ensure it is not zero or infinity.
Yitzach
61
The following came from a step in my EM homework. I came up with the answer that all of my resources (calculator, WolframAlpha, and a friend) were indicating as the correct answer, so it is not about the homework. This is about the permissibility of what was done.
1. [tex]x=\lim_{n\rightarrow\infty}n\sin\frac{\pi}{n}[/tex]
2. [tex]x=\lim_{n\rightarrow\infty}\frac{n}{\csc\frac{\pi}{n}}[/tex]
3. [tex]x=\lim_{n\rightarrow\infty}\frac{1}{\frac{\pi\cos\frac{\pi}{n}}{n^2\sin^2\frac{\pi}{n}}}[/tex]
4. [tex]x=\lim_{n\rightarrow\infty}\frac{n^2\sin^2\frac{\pi}{n}}{\pi\cos\frac{\pi}{n}}[/tex]
5. [tex]x=\lim_{n\rightarrow\infty}\frac{x^2}{\pi\cos\frac{\pi}{n}}[/tex]
6. [tex]\frac{1}{x}=\lim_{n\rightarrow\infty}\frac{1}{\pi\cos\frac{\pi}{n}}[/tex]
7. [tex]x=\lim_{n\rightarrow\infty}\pi\cos\frac{\pi}{n}[/tex]
8. [tex]x=\pi\cos0=\pi[/tex]
Given that the exponent on x in step 5 is not 1, x is not zero or infinity, and that x is not the entirety of the argument of the limit, can we/I conclude that this will work in general?
Other possible solutions between 1 and 8 include a change in variable, the limit if the series expansion at infinity, the squeeze theorem, or using the inverse of step two instead.
If x is known to exist and be a positive real number, then this method works, although it is presented mildly sloppily -- remember that lim A/B is (lim A)/(lim B) if both limits on the right hand side are known to exist, and the denominator is nonzero.
Note that [itex]x = +\infty[/itex] and x = 0 are also solutions to the extended real number equation
[tex]x = \frac{x^2}{\pi}[/tex]
By what you said here, I take it to mean that once an answer has been arrived at by this method, it would be advisable/required to check 0 and infinity to make sure that they are not the answer. In this case I knew that neither of those could be the answer based on the nature of the question and the fact that the answer had to exist or the question would not have been asked.
Why did you limit the answer to positive real numbers?
Really, I just wanted to avoid zero and +infinity. I could have said "nonzero real". (which avoids -infinity too, but ah well)
So you are aware or do you care that much simpler more direct arguments are available?
Fair enough. So is there a reason for real numbers?
Yes I was aware of other methods. I was wondering about the permissibility of what I did for if I wanted to do it again later. Notice that I mentioned four other methods in the initial post.
We are looking at a limit of real numbers, so the limit, if it exists, must be an extended real number.
FAQ: Permissibility of Limit Technique
What is the "Permissibility of Limit Technique"?
The Permissibility of Limit Technique is a mathematical method used to evaluate the limits of a function as the input approaches a certain value. It is commonly used in calculus and other advanced mathematical fields.
How does the Permissibility of Limit Technique work?
The technique involves manipulating the given function algebraically to simplify it and then substituting the desired input value into the simplified function. This allows for the evaluation of the limit at that specific input value.
When is the Permissibility of Limit Technique used?
The Permissibility of Limit Technique is used when the direct evaluation of a limit is not possible, either due to the complexity of the function or the input value being undefined. It is also used to understand the behavior of a function as it approaches a certain value.
What are the limitations of the Permissibility of Limit Technique?
While the technique is useful in many cases, it does have its limitations. It may not work for all functions, especially those with discontinuities or infinite limits. It also requires a strong understanding of algebra and limits to be applied correctly.
What are some real-world applications of the Permissibility of Limit Technique?
The Permissibility of Limit Technique has various real-world applications, including in physics, engineering, and economics. It can be used to calculate the velocity and acceleration of moving objects, determine the stability of structures, and analyze market trends and investments.
